Question about Refrigerators
My ice maker water becomes hot and no icecubes
  • Refrigerators Master
  • 5,323 Answers
May need to check the ice maker heating element with a meter
  • 175 Answers
SOURCE: No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Posted on Dec 17, 2006
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
SOURCE: Ice Maker overflow
my icemaker overfill can you help
Posted on Sep 01, 2008
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
  • 10 Answers
SOURCE: ice maker leaking
Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
Posted on Jul 24, 2009
Blue icecube maker
Clean or replace water level probe.
Jun 14, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
No ice in my Hotpoint Side by Side Refrigerator/Freezer Model CSX22GRZ
Do you mean that your icemaker is not able to make ice?
Waiting for your reply..
Feb 21, 2008 | Refrigerators
I have Maytag MTF1954ARA with ice maker which stopped working. Water is available, filter OK, Water inlet valve removed and tested OK. Is there something else to check before I have to remove/replace ice...
Pour about 3/4 cup of water into the icemaker . If it dumps the icecubes but doesn't refill with water , then replace the water inlet valve . If it doesn't dump the cubes , replace the icemaker . Make sure the coils are clean down by the compressor also .
Aug 02, 2009 | Maytag Refrigerators
Ice maker not making ice
see what postion the lever arm is may be is the water valve or the icemaker
Feb 24, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Where is the CCW setting on Ice Maker
not reccomnended to do its set from the manufacture, if you are experiencing smaller icecubes look into replacing your water filter or making sure water supply has not become resrticted
Oct 30, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
You won't get many suggestions with such little info. Is your water line connected? Is there water in the icecube tray? Is the auger not rotating?
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
LG ice maker only fills half of the cubes
On the ice maker you will see a little screw with a + or - printing check carefully on the side just turn it on the way of + it will increase the water time so you will have bigger icecube. hope i was helpful!
Jun 22, 2008 | Freezers
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Ice maker leaking
what brand refrigerator?
Nov 27, 2007 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
