Question about Cell Phones
Case open warning
I had to set disable (Case Open Warning) but some minute later it will be auto enable.
mdsaeed67
  • 849 Answers
SOURCE: can't reopen circular reference file in excel
  1. Click the Microsoft Office Button , click Excel Options, and then click the Formulas category.
  2. In the Calculation options section, select the Enable iterative calculation check box.
  3. To set the maximum number of times that Excel will recalculate, type the number of iterations in the Maximum Iterations box. The higher the number of iterations, the more time that Excel needs to calculate a worksheet.
  4. To set the maximum amount of change you will accept between calculation results, type the amount in the Maximum Change box. The smaller the number, the more accurate the result and the more time that Excel needs to calculate a worksheet.
Posted on Nov 05, 2008
s_4u_11
  • 535 Answers
SOURCE: WARNING!YOUR COMPUTER CASE HAS BEEN OPENING.
chak your ram its has been bad or damged
Posted on Jan 07, 2009
keeperoffire
  • 106 Answers
SOURCE: What is the gate open warning light mean
that means that your rear door isnt shut all the way or swith that sends the singnal to the dash light is bad.
Posted on Mar 08, 2009
DickCanFixIt
  • 948 Answers
SOURCE: Hp business pc/912: error while booting/ reset case disabled
Go into the BIOS and disable the error message. You will need to look around in the BIOS to find the exact location of the enable/disable setting for case intrusion.
Posted on May 22, 2009
welcomejee
  • 10594 Answers
SOURCE: "movie recording disabled". How do I enable it?
If you are using DVD-RW, format it because it got some error in data writing.
and if its DVD-R, use another disc and try to finalize existing DVD-R / DVD-RW to get data.
Thanks.
Posted on Sep 13, 2009
How to reset the case intrusion warning
Resetting the Chassis Intrusion Detector
  1. Enter system setup by pressing <F2> during the computer's start-up.
  1. Under the System Security tab, reset the Chassis Intrusion option by pressing the left- or right-arrow key to select Reset. Change the setting to Enabled, Enabled-Silent, or Disabled.
May 20, 2014 | Dell OptiPlex GX270 PC Desktop
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
Warning case open warning
power on your computer and press the delete button and go to a bios the disable the motherboard features on alerting case open.
Jul 11, 2011 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
How to disable chassis open warning
Open the case , there you should see a switch . Tie it with a cello tape so that it is in pressed state. This will stop the error.
Thanks
Mar 20, 2011 | Computers & Internet
Mother board does not make beep sound
this could be just about anything. Check to make sure the power supply is plugged in to all the correct ports, check to make sure the RAM seated properly.
Mar 05, 2011 | Intel Motherboard
Seat belt buzzer , how do you turn it off.
Hope this helps ya.. Cobra.. :-)
Belt-Minder® Deactivating/Activating Vehicles Built After 5/27/03
Preparation
  1. Before deactivating/activating the belt minder, set the parking brake.
  1. Place the transmission range selector lever in PARK.
  1. Place the ignition switch in the OFF position.
  1. Close all the vehicle doors.
  1. Unbuckle the driver and passenger safety belts.
  1. Turn the ignition switch to the RUN position. (Do not start the engine.)
  1. Wait until the safety belt warning lamp turns off (approximately 1 minute).
  1. NOTE: Step 3 must be completed within 50 seconds after the safety belt warning lamp turns off or the procedure must be repeated.
    For the seating position being disabled, buckle then unbuckle the safety belt 9 times, ending with the safety belt unbuckled.
  1. NOTE: After Step 3, the restraint system warning indicator lamp turns on for 3 seconds.
    Within 10 seconds of the safety belt warning indicator turning on, buckle then unbuckle the safety belt.
  1. The beltminder activation or deactivation is confirmed by the following sequences:
    • If the beltminder is enabled, this procedure will disable the beltminder for that specific seating position. The safety belt warning indicator lamp will flash 4 times per second for 3 seconds to confirm that the deactivation procedure was successful.
    • If the beltminder is disabled, this procedure will enable the beltminder for the specific seating postion. The safety belt warning indicator lamp will flash 4 times per second for 3 seconds followed by a second series of 4 flashes per second for 3 seconds to confirm that the activation procedure was successful.
  1. After confirmation, the deactivation/activation procedure is complete.
Vehicles Built Prior To 5/27/03
Preparation
  1. Place gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission).
  1. Unbuckle the driver safety belt.
  1. Place the parklamps/headlamps switch in the OFF position. (if vehicle is equipped with Autolamps, this will not affect the procedure.)
  1. Turn the ignition switch to the RUN position (Do not start the engine.)
  1. Wait until the safety belt warning lamp turns off (approximately 1 to 2 minutes).
  1. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
    Buckle then unbuckle the safety belt 3 times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
  1. Turn the parklamps/headlamps on then off.
  1. Buckle then unbuckle the safety belt 3 times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for 3 seconds.
  1. Within 7 seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled and disable the belt minder if enabled.
  1. The following sequence of events confirm the belt mnider is enabled:
    • flashing of the safety belt warning belt lamp 4 times per second for 3 seconds
    • 3 seconds with the safety belt lamp off
    • flashing the safety belt lamp 4 times per second for 3 seconds again
  1. The safety belt lamp flashing 4 times per second for 3 seconds provides confirmation of belt minder disabled.
Jun 15, 2010 | 2004 Ford F150
What is chassis intruder
Chasis intruder is a warning that your CPU has been opened by someone
it is normally used to warn you against unautorized BIOS or SYSTEM PASSWORD removal
There is a switch in your casing that detects this.
Leave this setting to enabled (recomemded)
Thanx and i hope this info is helpfull
Please dont forget to rate this solution
Jul 17, 2009 | ASUS P4P800 SE (890552603657) Motherboard
May 22, 2009 | HP Computers & Internet
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Boot up error showing "chassis has been opened"
Here is the solution. I had the same problem.
Chassis Warning
"Warning your chassis has been opened. Press F1 to continue. Press Del to enter setup menu."
Resolution
Enter Bios
Goto Intergrated Peripherals
Goto Onboard I/O setup
Find "Chassis Opened warning"
Set to “Disable”
Press F10 to save and exit changes
That all there is too it.
Nov 30, 2008 | Computers & Internet
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
