Question about Home Security
Manual for Arlec wireless door chime DC680 Series 2
Where can i find Heath zenith SL-6273 manual or how do i make the product play mp3
Most Heath Zenith product manuals are available here: . Searching for the SL-6273 found two versions of the wireless MP3 door chime. The direct link to the manual for the SL-6273-00 is .
Put the batteries in the door chime. To transfer an MP3 to the door chime, connect it to a computer with a USB cable. Open the folder to view files and drag the new (short, <= 20 seconds long) tune into the folder. Eject the door chime (like any USB hard drive) and remove the USB cable from the door chime.
Next press the Tune button to cycle through the tunes on the door chime for the front door chime. Stop when the desired tune is played. That will be played any time the front chime is pressed. If you add the jumper to pin 8, the door chime will ding as that is the rear rear door sound. For the front door, make sure that the switches (1-7) on the push button match those for the door chime.
I hope this helps.
Jun 02, 2017 | Heath Zenith Home Security
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
May 12, 2014 | Heath Zenith SL-6144 Specialty Series,...
What is the diode size for an IQ America wired doorbell DW2403a
pODUCT OVERviewThe IQ America Designer Series Wired/Wireless Door Chime features a glass and pewter cover for a contemporary look, and it can be used as a wireless or wired chime for your convenience.
  • Big Ben 8-note, Big Ben 2-note, traditional 8-note, traditional 2-note, traditional 1-note, birthday song, Merry Christmas, Auld Lang Syne, Beethoven and U.S. national anthem sound options
  • Up to 300 ft. wireless transmission range
  • Adjustable volume control
  • Wired or wireless design (wireless use requires a wireless push button, sold separately)
  • Glass and pewter cover
  • Easily add any IQ America wireless pushbutton (not included)
  • Doorbell pushbutton not included
  • MFG Model # : PC-5610
  • MFG Part # : PC-5610
Sep 14, 2013 | Desa International White Wireless Plug In...
Heath Zenith Wireless Door Chime won't turn off (after bad storm)
Possibly check the outdoor push button. It may be possible that it has moisture in it causing a short.
Mar 07, 2017 | Heath Zenith SL-6136-WH Basic Solutions...
Hello! i've purchased one of your door chimes
Each push button should have jumpers in the back of them. By the description you say its the wireless but your text describes wires. If it is the wireless there should be jumpers, little black blocks that make an electrical connection, inside the push buttons and the receiver. Be sure you read the manual about which ones go where for your dual operation.
Jun 24, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
My doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Dec 29, 2008 | Desa International White Wireless Plug In...
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
100 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
