Question about Boating
Evinrude 70 dies when put in gear - Boating
2 Suggested Answers
  • 63 Answers
SOURCE: evinrude approx 1973 wont stay started when put into gear
You have carb issues, you can try seafoam or better yet they need to cleaned.
Posted on May 05, 2013
1983 9.9 evinrude runs good on land but will not accelerate under load.
This happened to mine, I found out the gas lines were going bad and restricting the flow of gas
Apr 02, 2017 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Johnson 70hp model number A J70TLESB it starts fine and revs up neutral; ok but was lacking speed unless the ckoke is held in.then just stopped, will start and rev up but die when put in gear
I had a Evinrude 70 with the same problem. The cause was a connecting rod that wasn't clipped on the carb linkages. It is just to the left of the automatic choke. Unless this little clip is in place, you are only operating on one carb. Operate the throttle and make sure all three carbs are moving.
Holding the choke in, overgasses that one carb that is working fine.
I have a picture on my computer at home. Let me know by way of COMMENT under my post if you want to see it.
Dec 15, 2016 | Cars & Trucks
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
Jul 22, 2014 | Clymer Evinrude/johnson Manual 2 Stroke Ob...
Evinrude approx 1973 wont stay started when put into gear
May 04, 2013 | Boating
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
1996 evinrude outboard stalls when put in gear idles good in neutral & runs out good in gear but stalls idling in gear
Start by adjusting your idle mixture screw. Start at 1 1/2 turns out and with the engine in gear at an idle slowly turn the screw clockwise until the engine starts to die, then back off a half turn and that will be your proper setting. If you need to you can bump up your idle stop screw just a touch so it will hold also.
Mar 23, 2009 | Boating
Starts then dies when put in gear
does it do it only when engine is warm how the idle its going fine when its cold as soon you go over 70 km its start to do it let me know thanks pierre
Aug 17, 2008 | 2000 Chevrolet Blazer
Boating Logo
137 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
