What icon do i use on my handset to cool the room
I am trying to figure out the icons on my Delonghi conditioner and I don't know what the one is that is a circle and it looks like part of a face is for
generally that icon is for a setting that maintains a relative humidity in the room as against the temp setting
it is a comfort setting so that you will not feel cold at a setting
understanding that air conditioners are conditioners of the air and they do that by removing the humidity ( moisture present in the air) to allow you to perspire more freely and so feel cooler
with near no humidity in the room a temp setting of 25 c will feel too cold so the smiley icon is a setting where the humidity is kept at a level where the 25c feels "just right"
all is explained in the user manual that you can download from the manufacturers web site if you do not have one
Jun 25, 2017 | DeLonghi Heating & Cooling
What icon do i use on my handset to cool a room
Hello Glen Turner,
Snowflake (?)
Just guessing here
(a brand, make & model would've been really helpful)
Carnac the Magnificent
Jan 01, 2017 | Heating & Cooling
Can't find my manual. How do I get the messages off the phone, it's a Magicbox Logan three dect thingy.. Also how do you get a conference call happening?
Hi
To delete messages you need to first listen to them all on your machine via the BASE, then after all the messages have been played (which can be very boring) press and hold the DEL button. It will then ask you to confirm deletion by pressing OK. Not too sure about the conference call as mine does not have it. If however someone else in the same room wants to listen to the caller you can press the handsfree button (speaker icon) on BASE. If you want to speak to someone within your household in another room, you need to press OK on HANDSET, then press down to INTERCOM, press OK again and it will give you several options, INTERCOM ALL (where all available handsets can talk to each other), or HANDSET 1 or 2 to select a specific one. Hope I have helped and it does not sound too gibberish!
Regards
Feb 04, 2011 | Lands Phones
How do I make internal calls to another Panasonic KG-TGA711E handset in the house?
Making an intercom call
1 Press {INTERCOM}
2 Select the handset you want to page
by pressing the desired handset
number ({1} – {6}).
To stop paging, press {OFF}.
3 When you finish talking, press
{OFF}.
Answering an intercom call
1 Press {handset icon} or {speaker icon} to answer the
page.
2 When you finish talking, press
{OFF}.
Note:
When the ringer volume is set to off,
the handset rings at the low level for
the intercom calls.
Feb 20, 2010 | Panasonic (KX-TG1032S) Phone
How do I use the room monitor? when I go to menu then room monitor the display reads R.M extention?but when I enter 1 or 2 ect... it says not available
Very Cool Feature. With the handset off, press the mute button(menu/ok). then arrow down to ROOM MONITOR. press the mute button again. it will prompt "ROOM MONITOR EXTENSION?" press either 1 or 2 depending on what handset you are using(if 1 doesn't work, try 2). And that is it you can really hear what is going on. To stop monitoring, press cancel.
Have Fun,
SKA
Aug 20, 2009 | General Electric 28811FE2 Twin Cordless...
I want to put room temp on 30c but the default 24c
If you want the room at thirty C, it would appear you want the aircon to heat. To do this it would need to be a heatpump model which is capable of heating. If this is true, then it is a matter of changing the mode setting from cooling (default 24) to heating which would default at 30. Hope this helps. Look for a button with three or four icons, one should resemble an ice crystal (cooling) another should look like a radiating sun.
Jun 09, 2009 | LG Heating & Cooling
Lg vu
User must be logged in as Administrator or have administrator privileges to modify system files
Setting up the handset
1. On the handset, touch the Menu icon located in the lower left corner of the main screen.
2. Touch the Settings icon located on the bottom of the menu tabs.
3. Touch the Bluetooth icon.
4. Touch Turn On.
5. Touch Settings.
6. Touch My Device Visibility.
7. Touch to select On.
8. Touch Set.
Setting up the connection
1. On the PC, double click the My Bluetooth Places icon on the desktop.
2. Click View devices in range.
3. If the handset does not appear, click Search for devices in range.
4. Right click the icon representing the handset and click Pair Device.
5. Type a numerical pin code (example: 1234) in the Bluetooth PIN Code field and then click OK.
6. On the handset, an Accept? prompt will appear, touch Yes.
7. Type the same Bluetooth passcode (Bluetooth PIN Code) entered on the PC and touch OK.
8. On the PC, return to My Bluetooth Places.
9. Right click the icon representing the handset and click Discover Available Services.
10. Double click the Dial-up networking icon.
11. When the connection window opens, click Cancel.
12. Click Start, Settings, Control Panel and double click Phone and Modem Options.
13. Click the Modems tab.
14. Click to select Bluetooth Modem and click Properties.
15. Click the Advanced tab.
16. Type at+cgdcont=1,"IP","isp.cingular" in the Extra initialization commands field.
17. Click OK.
Making the connection
3. Right click the icon representing the handset and click Discover Available Services.
4. Double click the Dial-up networking icon.
5. Type ISP@CINGULARGPRS.COM in the User name field.
6. Type CINGULAR1 in the Password field.
7. In the Dial field, type *99#.
8. Click Dial.
You will now be connected to the AT&T data service
NOTE: I had to change every instance of "isp" to "wap" for this to work (including the Advanced Settings Tab), but y'all might not have to. Hope this helps.
Apr 22, 2009 | LG Vu CU920 Cellular Phone
Centrex air conditioner
Here are some icon that may help you.
COOL- this icon cool your room.
Dry- this icon control the humidity in your room but limit the coolness in your room (24deg C).
Fan- this icon run for fan only.
Heat- this icon heat your room.
Mar 11, 2008 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
