Question about HP Designjet T1200 Large Format Color Inkjet 44 549 ft h Color 2400 x 1200 USB Plotter Printer
Am facing error code 22.0 with hp designjet t1200 . How do I reset it??
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
Joed911
  • 4338 Answers
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 27, 2008
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: In designjet 800,what is System Error 20:10?
Here's a great page for that:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html
Posted on Sep 30, 2009
SOURCE: HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Posted on Dec 05, 2009
How i can cancel the purge tube process in hp t770 plotter?
Here is a service manual that might help you.
http://www.partsnow.com/docs/service-manuals/hp-designjet-t770-t1200-service-manual.pdf
May 24, 2014 | HP DESIGNJET T770 Printer
Hp designjet t1200 error code 80
80 ......... there is more to error code than just 80 please give full error code details for a useable solution .
eg 86:01 ( carriage motor transport error)
or 0c00340a is also a fault code
if you can supplye either full error code then I will attempt to help you resolve it thanks
Oct 07, 2013 | HP DesignJet Office Equipment & Supplies
Hp plotter T1200 ps gives error 22.1:10
Problem with "Ink Supply Station" P/NoQ6683-60188. Replace it..
If you are tech guy follow the suggestion:
Error reason: ISS divided in to two units, each unit will maintain that pressure to pump ink to print heads. The part called "rocker" push the elestomer bongo(black rubberized material) to pump ink. This rocker movement sensed by the respective sensors to calculate timely movement. If these sensors malfunction or variations in rocker movement causes error..
Remove/take out Ink supply station, two units of right & left, right unit not working properly, clean sensors & lubricate the drive shaft.. Follow the pics..,
Note: Technically if you are not sound don't do this activity..
2_16_2013_7_45_21_pm.jpg2_16_2013_7_45_46_pm.jpg2_16_2013_7_46_05_pm.jpg2_16_2013_7_46_30_pm.jpg2_16_2013_7_46_54_pm.jpg
Feb 16, 2013 | HP Designjet T1200 Large Format Color...
Error 59.2:00 in hp designjet T1200 i replaced formatter and hdd bt same issue?: pls i need the solution
First time are you opened this printer? or else some one attempted? This error indicating that re-used or un supported parts are installed..My suggestion replace with old parts check the error message..then do the trouble shoot. Error 06:00 replace formatter or Hard disc..replace one by one & do the diagnostic test then confirm the part condition, replace the defective part/parts ..But replace with new parts only..
Oct 21, 2011 | HP Designjet T1200 Large Format Color...
Hp t 1200 plotter erroor 41.01 code 0x10307002
Media_Axis motor malfunctioning/shut down.
Reconnect the drive motor connections. Perform the paper drive diagnostic,check media advance drive, replace PCA,,
Sep 08, 2011 | HP Designjet T1200 Large Format Color...
HP designjet 90 error code: 22.10
System Error: 22:10
Ink Supply Station failure.
Corrective Action: Replace the Ink Supply Station
(The Ink Supply Station is the mechanical part under the ink cartridges.)
Jun 13, 2011 | HP Designjet T1100ps Printer
Printing to HP Designjet T1200 from Linux, RHEL 5.3 Server. Error 61:01 wrong file format. The printer cannot process the job, how may I resolve this?
This can happen due to the firmware on the plotter, even if it happens only with some postscript files.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3980523&prodTypeId=18972&objectID=c02189041
Apr 20, 2011 | HP Designjet T1200 Large Format Color...
Fault code 22:10 hp designjet 500 plus printer
check ur iss (ink supply station) & clean them if problem persists then replaced the iss unit
Jul 30, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
HP Designjet T1200 Large Format  Color Inkjet  44  549 ft h Color  2400 x 1200  USB   Plotter Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
