Manual Removal procedure for Palladium Pro
The first step you must take in order to remove Palladium Pro is to
stop one of the following processes below. Only one of them will be
running.
Palladium.exe
PalladiumPro.exe
Palladiumantivirus.exe
Z.exe
To Stop this process you can browse to the file location shown below
and re-name the file first and then restart your computer. Then browse
to that file location again and delete the file.
The next step in Palladium Pro removal is to delete the following file:
Windows XP :
C:\Program Files\Palladium Pro\PalladiumPro.exe
C:\Documents and Settings\USER NAME\Application Data\Palladium.exe
C:\Documents and Settings\USER NAME\Application Data\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
Data\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium
Pro\Palladium Pro.lnk
- C:\Program Files\Startup\Palladium Pro.lnk
Windows Vista / Windows 7 :
C:\Users\YOUR USER NAME\AppData\Palladium.exe
C:\Program Files (x86)\Palladium Pro\PalladiumPro.exe
C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium Pro\Palladium Pro.lnk
C:\Program Files (x86)\Startup\Palladium Pro.lnk
C:\%AppData%\Z.exe
Once you have successfully deleted these traces, Palladium Pro
should no longer be running in your machine and now you should run a
complete virus scan for the system using
Spyware Doctor with Antivirus.
This will let you know whether you have been able to remove all the
traces of Palladium Pro successfully and also whether there is any
other threat still available in the system.
If you need advanced help or an expert we recommend www.onlinecomputerrepair.org
Palladium Pro Registry Removal Procedures
Now that your system is free from the Palladium Pro file traces that
have been mentioned above, it is time to get rid of the infected
registry items.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium Pro"
HKEY_CURRENT_USER\Software\Palladium Pro
It is important that you run a complete virus scan for your computer
when you are done with the removal procedure to ensure maximum
protection for the system. For that, we suggest you to run the scan
with
Palladium Pro Directories:
XP
- C:\Program Files\Palladium Pro\
- UPDATED: We have a report of it being at C:\Windows\Palladium Pro for some users.
Windows 7 / Windows Vista
C:\Program Files (x86) \Palladium Pro
Or mail me
[email protected] we will remove it through remote desktop support
