Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi modele 43uwx10b how to set convergence
SOURCE:
  • 1694 Answers
SOURCE: 43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
Posted on Nov 10, 2007
  • 927 Answers
SOURCE: HITACHI 43UWX10B SERVICE MANUAL
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Posted on Sep 06, 2008
SOURCE: HITACHI 43UWX10B Color Convergence
I have a yellow swoosh (shape of the nike swoosh) on the top of my screen with a blue 2" inch line under it. I also have a blue spot on the bottom left of my screen. I hit the Magic Focus to see if that would help and it did nothing. Help!
Posted on Oct 13, 2008
  • 254 Answers
SOURCE: Need schematic for Convergence PWB of Hitachi
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
click the link.
Posted on Mar 09, 2009
Ecollier2012
  • 3459 Answers
SOURCE: convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 19, 2009
Testimonial: "Thank you for the info. It was really helpful. TV is back in business. :)"
Color sepatation
thats the convergence ICs and associated resistors your model is the DP14G chassis and the Hitachi DP14G convergence kit is available from www.tvrepairworld.com and includes the two ICs associated resistors and the cd with repair instructions.
Oct 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
My tv has a bow in it every time a banner comes across
It is not unusual in these sets for things not to be perfectly straight---if the set has recently been repaired for a Convergence problem--someone may not have adjusted it correctly.
Understand: if it is a 43uwx10b Hitachi:
The green convergence is adjusted first for a grid of straight lines up and down and left/right---if the green grid is not straight you are going to see a bow when things scroll across the screen.
The other possible problem you may have is a convergence problem--if you go into the customer menu and try to adjust convergence--not the magic focus-- are the blue and red adjusting or not?
I know the HItachi sets very well--I own two of them and have repaired hundreds of them.
Let me know if you have more information or need advice--I am here to help people.
If this has helped you rate this solution as I do this here for free.
REGARDS, SD TECH
Nov 05, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Manual Convergence adjustment on Hitachi 43UWX10B
I would guess you missed a open resistor--there are only about 12 of them--how did you check them?
This set (43uwx10b) has a tiny blue micro switch on the front of the chassis---if you engage it from the front the set will go into the DECAM or convergence mode--let me know the CLU number on your original remote and I will scan and paste instructions---98% of the time if the set is wacked out and will not adjust one of the resistors is gone---ONE OF THE CHIPS GETS THEM.
SD TECH
Oct 31, 2009 | Hitachi 43UWX10B 43" Rear Projection...
As stated in your response to another person (Hitachi 43UWX10B)
Your post didn't get attached to the message in which you read the 'fix' for your set so the person who helped, will likely never see it.
You might try re-entering your brand/model info and sort through the results to find the original message.
Oct 24, 2009 | Hitachi 43UWX10B 43" Rear Projection...
42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
43uwx10b
They are Big Black ICs will have STK on them they are startup and convergence ICs They control set to turn on and off and convergence. Look for board that has them on it.2 of them together. If they are 110s use 180s ,Let me know what # on STKs you have.
Jan 06, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Color convergence
If your model is 43UWX10B you need two STK392-110 Convergence ICs. and one each of the following 1watt reseistors. 3.3 ohm, 1.8 ohm, 2.7 ohm, 1.5 ohm, 3.9 ohm, and 2.2 ohm they are in order RK42, 46, 50, 54, 58 and RK60.
You can get replacement ICs and resistors at the following link and they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Hitachi 43UWX10B 43" Rear Projection...
My Hitachi 43UWX10B television
Needs Convergence IC
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 03, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Convergennce
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Nov 11, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Set is still slightly out of convergence after repair
Download manual & get info at www.HitachiServiceUSA.com....
Oct 29, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
