Question about Simpson Washing Machines
My 9kg simpson washing machine lid sensor is stuffed i think cos my hot cold and warm lights all flicker on and it wont drain or spin
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
SOURCE: Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Posted on Feb 17, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
richroth
  • 9472 Answers
SOURCE: simpson eziset 750 - Model
This problem occurs due to a faulty lid lock switch. There is a update kit for your machine to resolve this problem. You will need to contact Simpson at the following number.
Simpson appliances are backed by a network of service agents and spares outlets throughout Australia.To book a service call please call 13 13 49. To order a spare part please call 13 13 50.
Richard Roth
The FixYa Team
Posted on Aug 09, 2011
Hey I have a simpson swt802 and the on the temperaturebutton the hot,warm,and cold buttons flash and beep and I don't know why now the machine wont start..please help
Read your operating owners manual or if you don't have one then do a Google search for "Simpson SWT802 operating manual" The number of beeps and flashes tell you which fault it is.
Nov 06, 2016 | Simpson Washing Machines
Hi my simpson esprit 550 has suddenly stopped spinning,does everything else fine,any suggestions wod b much appreciated,thanku
Has it pumped out? It wont spin if still full of water. Check for blockages etc in hoses and the pump. If its pumping out, there could be a problem with the brake release or it may be the lid switch. It wont spin if the machine thinks the lid is open. Older 550,s had a switch that was operated by a lug that stuck out of the back of the lid, newer ones have a magnetic switch under the top of the machine.
May 19, 2015 | Simpson Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
I have two questions regarding my washer. Q1) What do you think the problem is when the water selection is on cold only, or warm and cold, or the hot and cold, barely any water gets inside the washer even...
chnage the water valve for the water problem and if it doesn't drain you could have a bad lid switch or something going on with the pump,something could be stuck in it or it's bad.open and close the lid down if you don't hear a clicking sound it's broke or stick a screw driver into the hole that the lid switch closes into,keep the washer in spin and see if it drains when you push the screw driver down in the hole
Feb 22, 2011 | Kenmore 15864/15862 Top Load Washer
My Simpson Riviera 966 wont complete wash cycle,whats wrong with it ?
1) timer- it stays wherever you leave it and does that action.
2) No fill -cold- for rinse
3) No pump out
4) Syphoning- where is your drain hose ?
5) Set to " no spin" drip dry" -- reset control
6) Lid switch - not engaging
Sep 12, 2009 | Dishwashers
No cold cycle or spin
First, check the temperature of the hot water and make sure it is hot and not warm. If the water is hot then the the problem could be in two areas. 1: water valve 2: Timer.
This machine will not spin if the lid switch is faulty.
Dec 13, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
