Question about Bose Audio Players & Recorders
I cannot change the display setting on my bose wave music system III with the remote. what can I try?
simplemitch
  • 752 Answers
SOURCE: Remote control of Bose WaveMusicSystem
First have the remote tested. You can buy a basic Infra-red tester at Radioshack for about $6. If the remote is putting out signal, the Bose will have to be serviced. Call them and get an RMA # and they will fix it for a flat rate.
Posted on Sep 22, 2007
welcomejee
  • 10594 Answers
SOURCE: bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Posted on Sep 16, 2008
mrwtech
  • 59 Answers
SOURCE: how do i hookup my apple ipod to my bose wave music system?
you need a 3.5mm male TRS to stereo male RCA plugs. the TRS plug goes in the IPod headphone jack. the RCAs will plug into the line in jacks on the rear of the Wave. good luck.
Posted on Dec 05, 2008
SOURCE: bose acoustic wave music system
I have the same problem: ready to throw it out and get a new one
Posted on Dec 09, 2008
  • 120 Answers
SOURCE: bose wave radio signal fades in and out, cd stops and starts
i would check the power supply for bad solder joints or cracks in the traces on the printed circuit board, possible around the heaviest components (usually a transformer) or a loose connector.You can use the eraser end of a pencil to push on components to see if any of them cause the problem to manifest, and if so, turn off the power and reheat the solder connections to that component.
Posted on Jan 10, 2009
Need to know how to setup
Search Results
    Bose Support - Owner Manuals
    worldwide.bose.com/axa/en_au/...manuals/page.html
    Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo speakers, whole home products, home theatre systems and speakers and music ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
    Bose Support - Owner manuals for Multimedia speakers
    worldwide.bose.com/.../multimedia_speaker_manuals/p...
    Bose CorporationProduct Name. Downloads. SoundDock® Series III digital music system. Owner's guide. SoundDock® 10 digital music system - Sold from 2009 to present.
    Bose Support - Owner Manuals for Music systems
    Bose CorporationFind product information and owner manuals for Bose Music systems, Wave, Wave system ... Home theatre systems and speakers ... Multimedia speakers.
Jan 25, 2016 | Audio Players & Recorders
No display; is plugged in to functioning outlet :)
Can you turn it on and off from the machine without the remote?
Apr 04, 2014 | Bose Wave music system Multi-CD Changer...
There is no sound coming out of wave 3 music system, while playing CD , FM, AUX in. How to fix the issue ?
I have a similar as gift, big size remote, you havent mentioned that whether ur using an adapter 110volts or else it still would have worked but would short circuit after some use.
Oct 10, 2012 | Bose Wave Music System III - Graphite Gray
I own Wave Redio/CD. My new remote is Wave Music System and does not work. Why not?
The Bose Wave Radio and Wave Music System use different IR codes. It is no other reason other than Bose made the remotes incompatible. This is often done to prevent interferance with systems that may be close to each other.
Jun 10, 2011 | Bose Televison & Video
I have a Bose Wave Music System and I"m trying to
How are you connecting the sytem to your PC? are using an RCA cable (red and white connectors) from you computer to the system?
Mar 20, 2011 | Bose Acoustimass 6 III System
The remote for my Bose Wave radio-CD no longer works. I have changed the battery and put a new battery into another Bose remote--no luck and I want to play my Christmas CDs! Help!
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Dec 05, 2009 | Bose Wave Radio
What type of battery goes in the remote for a BOSE wave music system
We have a Bose Acoustic Wave Audio System II, and our remote uses nickel metal-hydride batteries CR2032.
Sep 29, 2009 | Bose Wave music system large Remote...
What batteries doe the bose wave music remote needs
We have a Bose Acoustic Wave Audio System II, and our remote uses a nickel-metal hydride battery CR2032.
Aug 31, 2009 | Bose Wave music system large Remote...
Bose wave music system
Sep 16, 2008 | Bose Wave Radio
32 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
