Question about GE Blenders
Need replacement part for GE 169106, plastic cog/gear at base of blender. No longer screws on....it's stripped.
We have had a GE model 169106 blender. It broke right away It is the plastic cog/gear at base of blender that looks like it has stripped, as it no longer screws on to the base and the blender does not "blend".
  • GE Master
  • 1,908 Answers
Http://kitchen.manualsonline.com/manuals/mfg/ge_appliances/169106.html
contact the dealer to order the parts you want by partsnumber ref.
Posted on Jan 01, 2017
I cant unscrew the bottom of the glass jar to clean it.
If u cannot unscrew it is a problem. People normally twist anti clockwise where as in the blenders to unscrew it is twisted clockwise.
Aug 11, 2014 | GE small appliance blenders 169106 User...
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
Blender base cog is stripped. Can it be replaced
yes you can get a new base. your best bet is to google the brand name and buy the part from the manufacturer
Aug 12, 2009 | Blenders
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Blenders Logo
213 people viewed this question
Top GE Blenders Experts
Pamela Leach
Pamela Leach
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GE Blender Expert? Answer questions, earn points and help others
