Question about Panasonic Washing Machines
U12 panasonic NA-F70B5 washing machine problum
  • Anonymous Jan 01, 2017
    Give me answers
    U12 paenasonic
blueextc3221
  • 15935 Answers
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
SOURCE: panasonic washing machine model no
it is due to the magnet attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. i got the same problem too but luckily the i found the magnet nearby the washing machine.
Posted on Jan 17, 2011
  • 6277 Answers
SOURCE: Hi friends, I have Panasonic
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
richroth
  • 9472 Answers
SOURCE: The error code U12 shows
The "U12" is due to the magnet that is attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. Either the magnet has come off or it is not aligned properly.
Posted on Jul 31, 2011
  • 2992 Answers
SOURCE: Panasonic model Na-f70b2 error. U12 and stop motor
Try this: it should give answers to the "self-diagnostics".
http://panasonic.ae/en/manuals/NA-F70B2-65B2.pdf
Posted on May 05, 2015
We have u-12 error in our Panasonic washing machine. How can I rectify it???
CODE U12
The door is being read as being open
Check door is closed
Check doorlatch etc.
Check door lock
Check wiring
Check electronic controller........cheers
Oct 12, 2016 | Washing Machines
Sir, we experiencing U-12 error in Panasonic washing machine since last week. What will be the solution??
CODE U12
Check door lock
Check wiring
Check electronic controller............cheers
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
My washing machines NA-F65B2 Error code U12
This has already been answered elsewhere. Search "error code u12 for na f65b2". Find previous answer there
Jul 09, 2015 | Washing Machines
May 05, 2015 | Washing Machines
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
Hi, I'm using Panasonic Aquabeat NA-F130T1.(13kg),Fuzzylogic,Toploading. It stops at end of wash mode before rinse and blinks U12 code. Pls advise? Thanks.
Hi there, I'm using Panasonoic F130T1 washing machine.
my problem is,the washing did'nt complete n the water remains in the machine.
Pls advice as how i could solve this problem,tq.
Azhari.
Jan 11, 2013 | Washing Machines
Panasonic washing machine model no NA F70B2 U12 problem just installed today shows U 12 when the cycle reaches Rinse and does not move on.
Dec 30, 2010 | Washing Machines
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
Washing Machines Logo
Top Panasonic Washing Machines Experts
SteveAlaska
micky dee
richie46
Are you a Panasonic Washing Machine Expert? Answer questions, earn points and help others
