How to adjust volume in LRIPL remote in airtel set top box.
5 Suggested Answers
SOURCE: set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Posted on Nov 18, 2007
  • 8909 Answers
SOURCE: how to connect two different
If you split the signal two ways out of your box, it will feed both sets with the same programme.
Posted on Jan 03, 2011
SOURCE: I have bought a TOSHIBA
How I can see movie on Toshiba Regza AV700 LCD TV
Posted on Aug 26, 2011
  • 49 Answers
SOURCE: volume control
not all remotes will program for all sets and if do may not have key features wanted or needed.
Posted on Jul 17, 2012
With this remote control, you can't. You should have its original remote control, to enter the service mode. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 16, 2016 | Akai Televison & Video
FIOS cable /set top box doesn't turn Samsung tv on or off or adjust volume
Check it by setting with an other code to your device brand, from the setup code list of the remote control. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 14, 2013 | Samsung TV Set Top Box Remote Control
Cannot adjust the volume - always too loud
One of a couple of possible issues here:
With set on volume goes way up on its own and will not with remote or buttons on set go down.
Put the remote away or remove batteries to see if it is doing this (unlikely but easy to check)
what issue do you have and are you using a cable or some kind of box with the set as they have Volume controls on them also.
Apr 05, 2012 | Televison & Video
I bought the magnavox and all my channels are
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
26 people viewed this question
