Looking to factory reset a 57H82 rear projection tv
  • 8617 Answers
SOURCE: Unknown AutoLock on my Philips rear projection tv
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Posted on Feb 02, 2008
  • 4402 Answers
SOURCE: Toshiba 57H82 Projection tv: sudden "off-on" problem
Convergence amp ic bad
Or send to
good luck
please mark the post with a fixya
Posted on Mar 14, 2008
SOURCE: how to reset tv
it should have it in the tv manual.
Posted on Oct 29, 2008
  • 788 Answers
SOURCE: Mitsubishi WS-55511 Rear Projection TV
Your symptom sounds like at least one damaged convergence IC.
On Mitsubishi's2.gif you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend replacing them both at the same time because the chips legs can fall off due to the heat of the IC. If you have a good low wattage soldering iron ~ 45W (available at radio shack) you can perform the repair yourself, and this will most likely take care of the entire issue.
I like to remove the board that the IC’s are on so that I can unsolder the connections and clean then up using solder wick (this is also available from radio shack). Removing the board is not a real issue as the connectors are all labeled with an alpha number, so that you can connect them back real easy. There are three in the middle towards the front that I like to mark with a sharpie as they are the red green and blue convergence coil connections (they are all the same size in a row). Just mark them with slashes, like I, II, III, or something like that. If you mix them up it is not a big issue, you can test swapping them around until the picture lines up.
Please be sure to remove the entire white heat sink compound on the heat sink and apply an even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
This repair from a good technician will normally run from $250.00 - $300.00, and sometimes more depending on your area.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact
Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10.00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in
California, they will have the OEM components that you will need.
Their site is
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Aug 21, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi rear projection tv. picture is shadowy/3D
This set uses two convergence chips--both need to be replaced and the set adjusted----If you know how to do good soldering I can tell you where to look and what usually needs to be replaced---Parts cost should be less than 20 dollars if you buy the parts on Ebay---
Most shops charge 300 or more for this type of repair---I just returned home from a set with this type of problem---in home total repair 250 total---If you cannot do the repair I suggest you shop around and find someone who can do it in your home---any good repair person can do this in about 1 hour---I am getting ready right now to do another one near where I live.
Posted on Oct 05, 2009
Tv will not turn on
I have the same problem power lite (red) flashes TV doesn't come on. Eager to hear a solution. I suspect a reset button will revive it.
Sep 02, 2009 | Toshiba 57H82 57" Rear Projection...
Need to remove screen cover
you have to remove the back of the tv to clean the inside screen.
Apr 29, 2009 | Toshiba 57H82 57" Rear Projection...
Service Manual for Toshiba 57H82
By the red being "off" I suspect you have a convergence problem and adjusting will bnot likely fix the problem. The convergence amps need to be replaced but if you email me I can send you the servoce manual... Just provide me with enough info in your mail, model number, because I get nearly 3000 emails a day and I won't likely remember what manual you're looking for...
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Dec 18, 2008 | Toshiba 57H82 57" Rear Projection...
Service manual for Toshiba 57H82
I found an owners manual and other info on your TV but not a maintenance/service manual. I would suggest contacting Customer support, See below:
Dec 17, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H93
I have the same exact problem that started today. Any ideas.
Sep 07, 2008 | Toshiba 57H82 57" Rear Projection...
57H82 Service Manual?
Emailed and sent via Pando...
May 13, 2008 | Toshiba 57H82 57" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
