Question about Refrigerators
How do I unlock the temperature controls on the front of the hisense 610 litre side by side fridge to make adjustments
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Buy bridal lehenga
http://www.kartohome.com/buy-bridal-lehenga
Buy bridal lehenga in kolkata, Buy bridal lehenga in india, Buy bridal lehenga in noida, Buy bridal lehengain mumbai, Buy bridal lehenga in banglore, Buy bridal lehenga in delhi, etc.
Posted on Jan 01, 2017
  • Kartohome online
    Kartohome online Jan 01, 2017
    Buy party wear lehenga
    http://www.kartohome.com/buy-party-wear-...
    Buy party wear lehengain kolkata, Buy party wear lehenga in india, Buy party wear lehenga in noida, Buy party wear lehenga in mumbai, Buy party wear lehenga in banglore, Buy party wear lehenga in delhi, etc.
  • Kartohome online
    Buy lehenga choli
    http://www.kartohome.com/buy-lehenga-cho...
    Buy lehenga choli in kolkata, Buy lehenga choli in india, Buy lehenga choli in noida, Buy lehenga choli in mumbai, Buy lehenga choli in banglore, Buy lehenga choli in delhi, etc.
What setting must my fridge and freezer be at. Thanks
RFA70 settings Controlling the Temperature of the Fridge Compartment The left hand control wheel on the front panel adjusts the internal fridge compartment temperature. The internal temperature should be 5?C or colder, although some sections such as the salad bin will be slightly warmer. The setting of the control wheel will depend on the location of the fridge freezer, the room temperature and how often the door is opened. The normal set point (marked by a 3 on the dial) is usually suitable. If you need to adjust the temperature turn the control wheel using a coin to avoid damage: Clockwise (higher number) - Colder Anti-clockwise (lower number) - Warmer
Here is a user manual go to page 6 http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Fridges/HBRFA60.pdf
APPLIANCE 911
Sep 04, 2016 | Refrigerators
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
I bought hisense HR6TFF222 a month ago, and then week later there's a problem occurs on the fridge part (the lower section), it's not working very well, it's warm as in room temperature while...
Ive just had the same issue as the op with the same model fridge. The warranty center said to adjust the front level feet to elivate the front of the unit open both doors , defrost for 8-12 hours at least. This seems to be a problem in the colder months of the year. Once a full defrost has occurred level the feet again , and turn your fridge back on. Problem solved
Dec 10, 2012 | Hisense Refrigerators
Fridge is not cooling
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope this helps.
Good luck.
Nov 28, 2012 | Whirlpool Mastermind
Refrigerator side is not cooling enough. Temperature is only in low 50's. Freezer side seems to be okay.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Dec 28, 2009 | Refrigerators
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
How to adjust fridge and freezer doors on Kelvinator C520 Litre
how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
Apr 04, 2009 | Refrigerators
Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Sep 16, 2008 | Hisense LCD1504 15 in. Television
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
