Question about Cell Phones
Pin code for 42686 - Cell Phones
Dead set KMC-42686
Check and replace damaged component/s in its main power regulator board. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Feb 25, 2013 | Televison & Video
Tip
PIN and PUK
I have seen a lot of posts here about unblocking a PIN and PUK code.
Hopefully this tip will help Fixya users who experience this problem, at one point in time.
First of all, the PIN and PUK codes are not phone codes, they are SIM card codes.
The PIN (Personal Identification Number) is a code that restricts access to your phone, through the SIM card.
If you insert a SIM card that has no PIN restriction, you will not be asked for the PIN code.
When you enter the wrong PIN more than five times, it will get blocked, and ask you for the PUK code.
The PUK (Personal Unblocking Code) is used to unblock a blocked PIN.
If your PIN is blocked, use your PUK to unblock it.
Tip:
The PIN and PUK being SIM card codes, no one else can provide them to you, not even your phone manufacturer, except your network service provider.
If you dont have your PIN and PUK, call your network service provider customer care and they will provide you with both the PIN and PUK codes, for free.
I hope this tip will help you in case your PIN gets blocked.
Thank you for using Fixya,
Kenneth.
on Apr 07, 2010 | Cell Phones
Unlock pin code nokia required for model 1661 2 I have forgotten my pin code please can you help thanks
Hi
The default PIN code is 0000.
If you changed it and forgot the PIN code please contact your service provider. They will provide you the default PIN code so that you can use your phone.
While you get the PIN code, service provider will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PIN code
This PIN code is FREE. You no need to pay any sum to get the PIN code
Thank You
Feb 25, 2011 | Cell Phones
My al jawal sim with my nokia phone was asking pin code but if i put the pin code ,it is code error.
Hi
Thank You
Jan 12, 2011 | Cell Phones
SAMSUNG S5233 WHY THEMES IS NOT DOWNLAOD ?
Tired of memorizing new PIN codes? We show you how to change your SIM card's various PIN and PUK codes in less than 5 seconds.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
<a href="http://www.5starandroid.com">Android Mobile</a>
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
Jazz pin and puk code
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Aug 31, 2010 | Cell Phones
I want to give keyguard pin code to my nokia 1203 mobile. But when I went in Setting and tried fro that It is throwig "Code error" message. Please suggest
Hi
Thank You
Aug 08, 2010 | Cell Phones
Entered PUK 00000000 then it asked me for my new pin code,what do i do??
the new pin code means you should enter any pin code of your choice.
Any pin code you enter at this point will be what your phone will recognize.
So you have to forge a pin code that you can easily remember. If possible write the pin code out in your dairy so that you can fall back to it in case you forget the pin code.
In summary, the new pin your phone is asking of is telling you to forge a pin code.
Good luck.
Mar 08, 2010 | LG Shine KE970 Cellular Phone
How to turn off the pin code of your sim card
you can disable the pin code in your phone on tools folder, or settings , select security and look for the pin code options there, enable or disable, select disable and enter your 4 digits pin code which was provided by your network, if you have changed the default pin code(which was provided by your network), enter your current pin code (code which you use to replace the default pin code) and pin security will be disabled.
good luck and take care.
Feb 23, 2010 | Nokia Cell Phones
I have an lg vu and i wanted to see what happens after the pin is gone 5 times now my screen just sayz puk blocked please need help!!!!!
If all else fails, you can use cellunlockstore.com for $1.99. Try the instructions below.
To change your SIM card's various PIN and PUK codes:
Change SIM Card PIN
Jul 19, 2009 | Cell Phones
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
