Question about Radio Communications
Do you repair wireless headset nw-3000? - Radio Communications
Microsoft Lifechat-LX-3000 , the wires got pulled out of the headset USB side , what colors go where ?
You can see if the wire is made corresponding to the USB 1.x/2.0 standard. (All USB cables should follow the standard, but many manufacturers don't respect this and use whatever cables they get cheap.)
The Pin-out and wire colors can be found here:
USB Wikipedia the free encyclopedia
(scroll down to "Pinouts", also provided below)
USB 1.x/2.0 standard pinout
1 VBUS Red (or orange) +5V
2 White (or gold) Data?
3 Green Data+
4 GNDBlack (or blue) Ground
Hope this helps!
Feb 17, 2013 | Microsoft LifeChat™ LX-3000 Headset
How to repair jabra
Any problem you are having with the Jabra headset you should be able to correct and properly sync the headset to a wireless phone.
Apr 24, 2012 | Jabra BT2080 Bluetooth Headset
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
My headset wont turn on
Unfotunately, this would indicate that the battery is no good on this one, you would have to invest in a new one as repair would not be very cost effective.
Hope this helps.
May 10, 2009 | Motorola Mobility H700 Wireless Headset
Broken wire to my microphone on my lifechat lx-3000
You cant wire then directly there is a USB D-A chip that controls the headset converting to 1/8" mini plugs may work one for the mic and one stereo plug for the earcups
Mar 30, 2009 | Microsoft LifeChat™ LX-3000 Headset
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
hi have motorola h700 bluetooth device but i forget my passcode how do i reset it again i tried many passcode like 0000, 1234, 1111 ,2222, 3333,4444,5555,6666,7777,8888,9999, but its not connecting wat do i do nw.. plz solve my problem.... my email address is
Aug 21, 2008 | Motorola Mobility Bluetooth...
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
