How do I put my RCA SCENIUM in usb mode? It has the USB port but don't give me the option to use my hard drive in the usb mode I should have mentioned it's a tv! Not a computer!
SOURCE: Unable to connect USB hard drive to KD-AVX33
I have a Lacy 160G laptop external HDD attached to it..It works fine... The format of the HDD should also be FAT32. The structure of the files should be Album/MP3
For a HDD that big look for software on the internet which can convert it from NTSF to FAT32 it should work perfectly.
The only thing I haven't been able to get working is videofiles...on the same HDD. Anyone got an idea?
Posted on Feb 26, 2008
Pterocarpous
  • 202 Answers
SOURCE: External Hard Drive -- too much power for my USB port on my computer
Hi mhjohn
First, this is actually a good thing in a way. The reason is, it is actually telling you right up front that your USB bus is underpowered for this device. That's a huge improvement over issues caused by underpowered USB buses in the previous model computers. In those, we were left to having to figure out what the problem was when a USB device inexplicably stopped or didn't work.
What is happening is, your new external hard disk drive (HDD) is trying to run off of power taken from your laptop's USB "bus" (circuitry). This is OK for devices needing low power. But in the case of external hard disks, it's "iffy" whether there'll be enough power on the USB bus to support them. Particularly on laptop computers.
You need only attach an A/C adapter to your external hard disk drive (HDD) and you should be OK. If that is not an option, connect a **powered** USB hub to your laptop and plug the external HDD to the hub instead.
By "powered" I mean a USB hub that comes w/ an A/C adapter. In either case, using a powered USB hub or attaching an A/C adapter to your hard disk drive will remove the external hard disk's power load from your laptop's USB bus and provide sufficient power for the HDD to run.
You can find USB hubs at Newegg.com and lots of other online high tech stores. I like Newegg because their prices are competitive, their customer service is excellent and there're customer reviews of most of their products there as well.
If you have any more questions, comments, observations - anything at all, just let us know. We're here to help.
Thank you,
BJ @:)
Posted on Apr 15, 2008
  • 3 Answers
SOURCE: export via USB to hard drive
The USB ports on this unit are non-functional unless you hack it. There are several methods of doing so, but the easiest is probably to purchase an upgrade kit from dvrupgrade.com. You can either purchase a replacement hard drive, or software to do it yourself.
After you do this, the USB ports can be used to connect a network device, and you can use different software programs to export and import programming. You will also have other features you normally wouldn't have on the stock unit. Good resources on this topic are tivocommunity.com and dealdatabase.com.
Posted on Jul 18, 2008
SOURCE: beeps and computer not reading USB port
usb drive get faulty. replace it.
Posted on Oct 14, 2008
  • 415 Answers
SOURCE: USB PORT FOR ZEBRA Z4M
It will not work with any drivers if you do not have a parallel port. You can get a pci card that has parallel port on it for use with the zebra z4m.
below is a link for the card that cost only $9.99
http://www.gogocost.com/xcart/product.php?productid=275
Posted on Feb 19, 2009
Hello! the problem is taking me to long to copy a small size file? even if i format it using transcend formatter. i already replace the usb cable. can u please kindly help me?! thanks
The cause of this problem is that either you're using an old USB 1.0 port or you have a USB 2.0 port in 1.0 mode, in the second case you can solve the problem by entering the BIOS right after powering on the PC by pressing f1 or f2 or f10, browse through BIOS setting until you find an option like "USB mode" and set it up to 2.0, I recommend you to call a friend who knows about BIOS tweaking to do this procedure for you.
If you have USB 1.0 capability only you can buy a new USB PCI card and install it to solve your speed problems, again I recommend you call a person that can do this procedure for you if you don't know how to do it yourself.
May 12, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
How do i open my flash drive when the drive is not securely put on the port
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Mar 03, 2011 | Dane-Elec DaneElec 4GB USB Drive Blue Hard...
I have 4 gb kingston pen drive but its not formatting and giving the msg "Windows unable to complete the format" and also usb memory not showing 0 bytes plz tell me the solution of this problem
ports(com&lpt)right click update driver or
then right click on the drive select format
don
Feb 10, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Maxtor external hard drive cannot be detect
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the harddrive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your harddrive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your harddrive to be detected automatically.
Hope this helps you out.
Nov 24, 2009 | Maxtor Hard Drive
Clicking sound when I plug in hard drive and computer does not pick it up. What's wrong?
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Nov 23, 2009 | Western Digital My Book Essential Edition...
It wont recognize on the computer on any type of connection
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Nov 21, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I cannot retrieve what I put on my Maxtor one touch. Any suggestions.
Nov 21, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
My computer does not acknowledge my hard drive.
Nov 21, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
320 GB transcend external Hard dics is not at all detected
Nov 16, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
