Question about Kenmore Washing Machines
My Kenmore washing&dryer machine model 363.71542411 washing machine leaking in the bottom
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
SOURCE: washing machine broken, kenmore model 110.92274100
I have the same problem as posted on mar 30, 08. seems like the clutch will not engage, the motor turns but the drum won't spin (wash. move). would you give us follow -up instructions for clutch & gear case on how to replace it.
Posted on Jul 27, 2008
danromarris
  • 101 Answers
SOURCE: Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Posted on Jan 21, 2009
  • 25 Answers
SOURCE: Kenmore washer dryer age?
Next to the serial number there should be a manufacter date. that is when it was made. I am guessing 2 years old.
But check on the back, it is peobaly printed on a small metal tag.
Most electronics have a manufacter date posted on them for warrenty sake. yours may still have a warrenty. you can also go to Kenmore website and in the search area type in the serial number and it can tell lots of info including if it is still under warrenty. wouldn't that be a nice surprise!
Posted on Jul 26, 2009
  • 23 Answers
SOURCE: water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Posted on Jul 31, 2009
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water leaking from bottom ofoasis top loading machine
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore 80 series topload machine is leaking water
This machine has a direct drive pump, in all likelyhood the pump is leaking...unplug machine...pull it out...tip machine on its back so you can access the bottom, if it is the pump there should be water around where the pump connects to the motor, if it is the pump it is a simple process of releasing 2 clips and taking the inlet and outlet pipes off the pump..install new pump the way you took old one off. you can obtain the part from www.repairclinic.com If you would like to give me more details on your dryer i may be able to work out what is wrong with it.
Jun 23, 2009 | Kenmore 24032\24036 Top Load Washer
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
Leaking from bottom of washer
Do you have the little door at the bottom to collect lint and stuff that goes through the washer? I had a leaking problem once when I simply didn't tighten it enough. Check that.
May 06, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
Mar 24, 2009 | Kenmore Washing Machines
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Kenmore 'Elite' washing machine
    remove the bottom panel is is held in place with 3 torx screws
    Apr 28, 2008 | Kenmore Elite HE4 Electric Dryer
    Washing Machines Logo
    29 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
