Question about Garden
Husqy cth2542 starts and can move both in forward and reverse and seems to rev fine, but as soon as the blade is engaged) the engine looses power and turns off if the blades are not disengaged.
    Sergeant:
  • 303 Answers
It sounds like a safety switch issue. It may be possible one of the deck PTO safety switches has gone out or the connector plug is loose or broken. Some newer mowers have fuses located either somewhere around the dash or under the seat check to see if there are fuses and if one is bad it could cause a similar problem to a bad or disconnected safety switch
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 202 Answers
SOURCE: Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Posted on Jul 24, 2009
mickey813
  • 472 Answers
SOURCE: Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Posted on Oct 08, 2009
Testimonial: "This is what I concluded too. I have ordered the part, and we'll see."
mickey813
  • 472 Answers
SOURCE: After stopping, tractor does not engage in forward or reverse
sounds like the by pass rod has been pulled out
Posted on May 08, 2010
wadembly
  • 513 Answers
SOURCE: Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Posted on Jun 27, 2010
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
No forward engagement in drive position
If engine revs go high and no forward movement you most likely need a new transmission
Jul 11, 2017 | 1999 Ford Contour
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
Nov 29, 2013 | Audi Cars & Trucks
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
May 14, 2009 | Mtd Garden
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
