Question about Miscellaneous
15 metre don't work what are you going to do about it?
How many squared metres is there in 7,540 meters? Of staircase carpet.
It depends on the width. If it's one metre wide the area is 7.540 metres. If it's two metres wide then the area is 15,080 square metres. If it's three metres wide then the area is 22.620 square metres.
Jan 29, 2017 | Miscellaneous
How many square metres in 7.54 metres? Staircase carpet.
That is a question that is impossible to answer. You have to have another figure 7.54 metres by what length or width?
Or if you have 7.54 SQUARE metres, it might be 1 metre wide and 7.54 metres long.
Just not enough information. To work out square metres, you just multiple length by width.
How many yards to cover 30ft/40ft 4 inches deep in concrete
That may be ok for the US, but in Europe you would need cubic metres.
I yd = 0.914 m, 1 cubic yd = 0.914 x .914 x .1914 = 0.764
So 14.66 cu. yds is 14.66 x 0.764 = 11.2 cubic metres - with a bit of luck!
Mar 26, 2015 | Building Materials
40.3 square metres is how many cubic metres n how many cubic yards
Square metres is a measure of area. Cubic metres and cubic yards is a measure of volume. There is no conversion between them without a third dimension.
Consider a storeroom that's 40.3 square metres in area. How much stuff can you store in it? Well, that depends on how high the ceiling is. If the ceiling is 2 metres high then the volume of the room is 80.6 cubic metres. If the ceiling is 3 metres high then the volume is 120.9 cubic metres.
One cubic metre is about 1.31 cubic yards.
Jan 27, 2015 | Office Equipment & Supplies
How many cubic metres in a room 194cm x 194cm
That depends on the height of the ceiling.
194cm x 194cm is 3.7636 square metres.
If the ceiling is 2 metres high then the room is 7.5272 cubic metres.
If the ceiling is 3 metres high then the room is 11.2908 cubic metres.
Feb 06, 2014 | Office Equipment & Supplies
Convert metres in acres
I hope you mean square metres because you can't convert metres (length) to acres (area).
60600 square metres is about 14.97 acres. 15 acres would be about 60700 square metres.
Oct 25, 2013 | Office Equipment & Supplies
Speedometer is not working on my car
*Check the 2nd end of the cable connected to engine.. move the cable end clockwise and check if the metre is moving. If yes then there is geyor inside the engine area where the 2nd end is connected. you've to replace the geyor.*Check the connection of metre cable with metre... you have to remove metre console.
if its ok then you have to replace the cable.
otherwise you've to repair the metre
Aug 19, 2012 | 1992 Toyota Tercel
Miscellaneous Logo
26 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
