Question about Dishwashers
De Longhi dishwasher model, DEDW650S not working. Readout display keeps cycling through time settings H-01, H-02,etc. Machine can't be started while this continues & won't start no matter what.
We have done everything mentioned in the manual to trouble shoot - but the manual says nothing about this problem. Is it a faulty readout display? We've tried turning off and on the power at the fuse box.
  • 5911 Answers
SOURCE: whirlpool duet washer
Is there a number associated with the "F" display? Usually when the washer displays anything with an "F" it has generated a fault code. But, it will usually have a number or another set of letters associated with it indicating what area of the washer has generated the problem. If you could double-check and provide more info I might be able to lead you in the right direction.
Posted on Apr 30, 2007
SOURCE: samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then 1. Turn AC power OFF, unplug from wall 2. HAVE YOU TURNED THE POWER OFF? 3. Unscrew two visible screws on the back of the machine near the top 4. Take back lid off by pull up which will expose all the wires at the back 5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw) 6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it. 7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test. 8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
Posted on Oct 03, 2009
  • 901 Answers
SOURCE: my Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
Posted on May 28, 2010
  • 9098 Answers
SOURCE: Model jes636wk01 the readout display reads E 1 and
This is a common 700Wcounter top oven with no special features, so honestly it will be more economical to replace it rather then repair it.
That said, you probably have a failed keypad.
Posted on Jan 19, 2011
  • 155 Answers
SOURCE: I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Posted on Aug 03, 2012
De longhi coffee machine- coffee pours into the middle of machine, not through spout
the main feed line ( is probably disconected to the spout ... take of the top ( screws ) and look for the feeder line normally they just put a tie rap on the edge of it ... might of come apart so now its not going true the main line and get water all over the place ;)
May 11, 2017 | Coffee Makers & Espresso Machines
Air Conditioner User Manuals
Air Conditioners:
Pelonis units are manufactured by Midea Group. You will need to contact them for the manual they can be found at the following link:Download
or Via their contact page (depending on your country):Download
De' Longhi
De' Longhi PAC A120E Portable Air Conditioner Download
De' Longhi PAC C120E Portable Air Conditioner Download
De' Longhi PAC T110P Portable Air Conditioner Download
De' Longhi PAC WE125 Portable Air Conditioner Download
on Jun 08, 2011 | Heating & Cooling
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Jan 04, 2011 | Dishwashers
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Kenmore Elite 15962990 will not start
So far, I'm not very impressed with this website. I posted a problem with a Kenmore Elite 15962990. FixYa emailed me back, saying: "We wanted to find out if you still need a solution for the Kenmore 24 in. 15932 Built-in Dishwasher Problem". So now I'm confused. I'm supposed to trust advice from somebody who can't even get the model number right? And FixYa keeps telling me I'm dealing with a top load clothes washer instead of a dishwasher.
Anyway, the problem still exists. I know there must be some way to reset it or put it in "maintenance mode". But none of the button sequences I saw online will work because my specific model does not have the buttons mentioned.
Feb 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Dec 30, 2005 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
Top Dishwashers Experts
