Question about Dishwashers
De Longhi dishwasher model DEDW650S; The display readout keeps on cycling through start times (H01, H02, H03, etc. Machine can't be started.
We have done everything mentioned in the manual to trouble shoot - but the manual says nothing about this problem. Is it a faulty readout display? (We've tried turning off and on the power at the fuse box).
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then 1. Turn AC power OFF, unplug from wall 2. HAVE YOU TURNED THE POWER OFF? 3. Unscrew two visible screws on the back of the machine near the top 4. Take back lid off by pull up which will expose all the wires at the back 5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw) 6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it. 7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test. 8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
Posted on Oct 03, 2009
  • 901 Answers
SOURCE: my Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
Posted on May 28, 2010
  • 155 Answers
SOURCE: I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Posted on Aug 03, 2012
My Westinghouse dishwasher is displaying HO2 what does it mean.?
H01-H24 Delay has been selected.so H02 means you have selected two hours delay.
Cancel delay setting if you don't need it.
Time Indicator and delay display:
The time indicator displays the program time and time
remaining for the program
In addition, you can delay the start of the program by
pressing the "+" and "-" buttons before the program is
commenced The delay function is indicated by the letter
"H" followed by the number of hours selected
If you want to change the delay time, you can reset it by
pressing START/PAUSE and then using the "+" and "-"
buttons to select the new delay time, then press START/
PAUSE to activate
Westinghouse WSF6606 User Manual Failure Codes And What To Do In Case Of...
Oct 25, 2017 | Westinghouse Dishwashers
De longhi coffee machine- coffee pours into the middle of machine, not through spout
the main feed line ( is probably disconected to the spout ... take of the top ( screws ) and look for the feeder line normally they just put a tie rap on the edge of it ... might of come apart so now its not going true the main line and get water all over the place ;)
May 11, 2017 | Coffee Makers & Espresso Machines
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Display has error code h01 and dishwasher won't run model is SMS63M08AU
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Mar 06, 2011 | Bosch Dishwashers
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
