Question about Kitchen Appliances - Others
Gfe28 touchpad icemaker I can't turn it on - Kitchen Appliances - Others
Gfe28 fridge with a sa 66 code when plugged in
GE refrigerators and a lot of new appliances have a mode called sabbath mode or SA 66. it turns off your lights and advanced features for the weekend. To exit sabbath mode push and hold light and lock for 3 seconds, or for some models it's light and alarm for 3 seconds.
Jun 30, 2015 | GE Refrigerators
Hoe schakel ik de touchpad van mijn HP 4720s uit in Windows 7?
In de manual staat:
"Turning the TouchPad on and off
The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off.
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator."
Laat hier even weten of dat werkt...
Jul 04, 2014 | HEWLETT-PACKARD HP ProBook 4720s 173...
Where is the touchpad lock on the Hp probook laptop.
Hi.
Turn off the touchpad Most HP notebooks come with an on/off button near the touchpad. If you do not wish to use the touchpad at this time, press this button. Press it again when you wish to use this accessory again. If the notebook does not have an on/off button for the touchpad, touch and hold the top-left corner of the touchpad for approximately 5 seconds to disable it and do this again to activate it. When the touchpad is disabled, a small light will illuminate on the touchpad and an icon will appear briefly of the touchpad with a line through it. When the touchpad is activated, a small light will turn off on the touchpad and an icon will appear briefly of the touchpad. Alternatively, if the notebook does not have an on/off button for the touchpad, and you wish to turn the touchpad off, open the Mouse Properties window, select the Device Settings tab, and click the Disable button. You may re-enable the touchpad from here at any point.
Regards.
Sep 05, 2011 | HEWLETT-PACKARD ProBook 4520s Notebook
I have a HP Probook laptop and my mouse (touch pad) is locked & I don't know how to unlock it. I have tried turning it off and removing the battery.
Based on the User Guide :
the indicator is on the top left side of TouchPad zone.
Good Luck
Feb 08, 2011 | HEWLETT-PACKARD HP 4525s ProBook
How to unlock touchpad of hp probook 4520s laptop
Touchpad zone is on upper left of the touchpad:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 02, 2010 | HEWLETT-PACKARD ProBook 4520s
Touchpad off
You can find a small button on the touchpad, make sure that it is turned on. If it is turned on and still the touchpad is off, then the issue might be with the corrupted touchpad drivers. We can try by reinstalling the touchpad drivers
Visit the below link for more information
http://notebook-solutions.blogspot.com/2009/07/how-to-uninstall-and-reinstall-touchpad.html
Aug 20, 2010 | Computers & Internet
Touchpad not workin at all
u can turn on or turn off the touchpad functionality of ur notebook..what must have happened is u would have turned off the touchpad of ur notebook by mistake & now u dont know how to turn it on....The key to turn on the touchpad can be different on different notebooks...so it would have been easier for me to provide u a resolution if u would have also mentioned the model of ur notebook... Generally there is a small button just beside the touchpad which is used to turn or off the tochpad, if the small button is amber in color then the touchpad is turned off & if its blue in color then touchpad is on...otherwise sometimes there is no button beside the touchpad & then there is a key combination to turn on or off the touchpad & it is Fn+F7....
try this out, it might work for u, if it works then let me know by rating this solution...
Jul 10, 2010 | Microsoft Windows Vista Home Premium with...
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
How do i turn on my touchpad
if there is not a buttom around the area of the touchpad to turn it on, then maybe, either the touchpad driver may not be installed, or the touchpad on/off switch (in the control panel) may not be turned on.
Apr 02, 2009 | HP Pavilion Ze4805us Notebook
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
Kitchen Appliances - Others Logo
56 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
