Question about GE Dishwashers
The upper spray arm on my ge adorable dishwasher fell off. These are what I found in the tub along with the arm. How do I reassemble and is the clear piece broken?
  • GE Master
  • 4,397 Answers
Doesn't appear broken. Such designs are often used as a spring clip, a spacer, a retainer or a device to provide a directional location.
Sorry I don't know how it would be assembled but as there are only a few parts there can only be a small number of combinations.
Posted on Jan 01, 2017
  • 111 Answers
SOURCE: upper spray arms not spraying water
It sounds like you have a model that has a pot washer cycle that blocks water flow to those arms. What cycles are on your keypad? Sounds like you have it set or single rack wash
Posted on Dec 18, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
JoshOHoward
  • 63 Answers
SOURCE: Upper Spray Arm in the dishwasher has fallen off
If you cannot just twist it so it screws back on a part was broken.
So I suggest you contact the manufacturer about this. Im sure that will be much more helpful!
Posted on Feb 06, 2009
SOURCE: upper spray arm broke off
I hope it did not break, only came off. I had the same problem. You have to unscrew the round part from the ceiling of the dishwasher, put the three pieces together, easy, and then screw the whole thing back. No tools needed. Top rack can stay on while working. It helps if the dishwasher is empty. If the threading is good, this should solve the problem.
Posted on Apr 16, 2009
SOURCE: broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Posted on Aug 29, 2009
Upper arm spray fell off my Indesit dishwasher. How do I put it back on?
Usually, there is a small stainless steel sc rew with a knurled edge. It fixes through the central boss of the spray bar. You should find it in the bottom of the machine in the strainer, or hiding in the bottom somewhere.
Jun 09, 2016 | Indesit Dishwashers
Question relates to an AEG 80860 Favorit Dishwasher pnc 911371032. theb upper spray arm fell off and i have examined it and the central holding device. they do not appear to be damaged but when i tr
1. To remove upper basket spray arm, tilt it down hard.
2. Clean spray arms jets.
3. Place cleaned upper basket spray arm back in position against the connecting piece: press the two together
firmly, until you feel them snap into place.
Dado
Jan 13, 2015 | AEG Dishwashers
GE Dishwasher / Model#: GLD4400N10WW Serial#: AS837876B We have had the dishwasher for 14 months. No problems until now. 1) Soap does not empty completely out of the soap compartment. 2) Soap residue...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Nov 06, 2010 | GE GLD4400NWW / GLD4400NBB / GLD4400NCC...
Ther top spray arm fell off the dishwasher
THERE IS PROBABLY A BIG PLASTIC NUT THAT IS STILL SCREWED ON THE UPPER TUB.THIS WILL UNSCREW AND WILL COME AS ONE PIECE IN A KIT.
Mar 01, 2010 | Frigidaire Dishwashers
Upper spray arm soes not spin
HI,
YOU WILL PROBABLY FIND THE TOP SPRAY ARM IS BLOCKED WITH FOOD. UNSCREW THE SPRAY ARM AND MAKE SURE ALL THE SMALL HOLES ARE CLEAR OF ANY BLOCKAGES AS THIS IS WHERE THE WATER COMES OUT OF TO WASH THE PLATES.IF THESES ARE BLOCKED THEN YOU GET POOR WASH RESULTS.
Jan 23, 2010 | GE Dishwashers
UPPER LEVEL SPRAY DOES NOT SPIN - UPPER LEVEL NOT
plugged spray arm holes, pump intake partially blocked, too little water getting in tub cuz screen in fill valve has debri
Dec 21, 2009 | KitchenAid KUDC25CH Dishwasher
Upper rinse arm fell off. How does it reattach?
usually it will clip to the basket that holds cups and the like, and engages with the water outlet when the basket is slid into position. Some spray arms have a locking ring that, when the spray bar is held in place, rotates clockwise (if viewed from underneath) and locks the spraybar in place.
Nov 06, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Upper spray arm fell off, can not repair nor find part
I had the same problem, but was able to find the replacement part at http://www.partselect.com/shipping.aspx. My old arm also has the number 1544681 on it. If needed use model number PLD2855RFC1 to locate the same part. Good luck!
Mar 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Upper spray arms not spraying water
Dec 08, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwashers Logo
119 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
