Question about Dishwashers
Sherwood micro, doesnt stop filling
I have a sherwood micro glass washer and it doesnt stop filling up. please help!!!!!
    Problem Solver:
  • 5 Answers
Sorry this reply late but might be of use for others. The water level is controlled by an electrical valve operated by a pressure switch. If filling happens even when not plugged in then just change valve.If only when on then you need to check the rubber hose from air chamber (upside-down egg cup mounted inside wash tank) make sure it is pushed on and not split, if ok then adjust or replace level control pressure switch (wind out centre plastic screw a little at a time, then automatically fill / drain the machine untill level correct. Hope this helps, ensure you turn off electrics b4 touching
Andy
Tri Catering Equipment
Posted on Dec 21, 2009
  • 297 Answers
Is your float working,it maybe jammed, it looks like a cone see if it moves up and down. if not this is your problem.it most likely is food get it out and is should work right.
Posted on Jul 21, 2009
My washer doesnt stop filling with water?
Sorry to read about your problem, I hope this helps you out.
you may have a defective water fill sensor
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hotpoint GE VWSR4150DWW WASHER
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
My kenmore 800 washer stops mid fill. i push in
sounds like the timer has a bad spot in it probaby a factory thin spot in the dial
it's where the coil or filiment has a gap even a micro gap or wear spot can cause this
Jul 29, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Filling up won't stop
hi. thanks for the question .if the water would only shut off ,by turning off the water .replace the water valve thanks the appliance doc
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
May 22, 2008 | Maytag Legacy Series Top Load Washer
Ice maker does not make ice and the in-door water is not working properly - it keeps running.
the water in the door problem after you fill up your cup with water it keeps running all over the floor.. it sounds like its a stuck contact on a micro switch inside the door compartment. that lever you are pushing your glass onto is atached to a little switch and if the contacts stay closed (like when a glass is pushing on it) the machine thinks "hey he still wants water". next time it does that try pushing on the spot you put the glass onto a couple of time to see if it stops the water. if so it most likely is the switch. to confirm that is the case you will have to open the plastic moulding from the fridge door to gain access to the switch.( always unplug any electricall device before openning to ensure your hair doesnt end up standing striaght up like a punk rocker) you will know which switch is the one you want to check by depressing the water lever on the front. Ohm check the switch for continuity to see if it gives you proper readings or it is in fact a bunk switch. it also could be a mechanical problem as the lever once unpressed is not opening the switch back up once the glass is removed but that is not as likely unless you are ramming the glass into the water dispensor
hope it helps
VeeDubb
Apr 23, 2008 | Refrigerators
My washer washes, but doesnt rinse...
I sounds like it needs a new timer.
Oct 08, 2007 | Washing Machines
Dishwashers Logo
250 people viewed this question
Top Dishwashers Experts
