Question about Engel Refrigerators
My 40L engel has the light on but is not running. The fuse seems ok. Would it be the compressor?
2 Suggested Answers
  • 17155 Answers
SOURCE: 1995 GMC A/.C compressor wont run
bypass the low pressure cut off and put in more freon
Posted on Aug 24, 2012
I bought this 40l engel today . I plug it in but nothing happens.
You may have to turn it on or it may be no good.
Sep 04, 2017 | Engel Refrigerators
I have a 40l engel that isn't cooling any more. Working fine as a freezer a week or two ago. Sounds like it's running but could be the fan. Is there any way to tell if the compressor is operating?
if one side outlet is hot it is pumping. the other side should be cold. It might be short of refrigerant or not pumping. Is the compressor very hot?
May 02, 2017 | Engel Refrigerators
Why does my engel MT45F-U1 fridge and freezer vibrate and make so much noise?
have u checked the groumets on the compressor? more than like are bad
Apr 20, 2015 | Engel Refrigerators
At first i smelt a burning smell then found the fuse had blown,i replaced the fuse and worked for a while then the motor was geting hot and the fridge wouldnt stay cold
it means your compressor hi pressure cause of blown fuse check the condenser fan if running ok if not replace capacitor or lubricate main shaft. then observe your comp. if working continues.
Feb 19, 2011 | Engel 43 Qt.Portable Freezer.
Motor cycles on /off every few seconds
Bad relay on compressor or bad compressor.
Apr 07, 2010 | Engel 43 Qt.Portable Freezer.
Starts running for short time then stops
Sounds like the compressor has fused windings. The only way is to get it checked by a refrigeration technician. It may only be a start relay.
Regs,
Hawk
Jan 16, 2010 | Engel Refrigerators
Zanussi ZX 57/3 fridge and freezer not working
Hi . Most freezers with the condenser coils at the back do not work when the temperature where it is placed gets below (( 5 degree c ))?? IE in a garage if it is freezing weather outside. One solution is somehow to keep the condenser compartment warm. Check the makers website. for what they say about it
Jan 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Refrigerators Logo
32 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
