Question about Garden
Two mowers haven't been used in two months and will not start. One will start with starter fluid but will not run. The other doesn't seem to have spark.
    Top Expert:
  • Garden Master
  • 12,962 Answers
One that starts with starter fluid needs to have carburetor cleaned out. Other one needs to have ignition circuit repair - possible bad coil.
Posted on Jan 01, 2017
Mower will not start
You are have to clean carburetor and you may do it using bicle pump takes 2 min
May 22, 2014 | Garden
My craftsman tractor will not run. seems like it is not getting any gas
you can test this real easy by squirting starter fluid in the intake and trying to start. If it starts and stays running, good-you may or may not have to keep using starter fluid. You might try new spark plug.
If starter fluid does not work, then you have a problem with spark plug, spark plug lead from the coil or a bad coil.
Sep 05, 2013 | Craftsman Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Crafstman push mower with a brigs and stratton 675 engine is very hard to start. the mower is only two years old. Any suggestions?
how old is the gas you are using?more than 30days from the pump is to old for a small engine
Jun 10, 2012 | Garden
Mtd yard tractor will turn over will not start
if it doesn't fire with starting fluid then there is a problem with spark unplug the connector at the engine and try starting fluid again if it fires with the small connector unplugged the it could be a safety switch if no then pull the cover off the top of the engine and check the coil
May 20, 2012 | Garden
Have 2 problems with my 2006 Toro lawn mower model 20070. I have used a total of 15 times and don't understand how it could fail with so little usage? 1) The engine will start with the cord but not...
The starter gears engage the bottom of the flywheel when starting the mower with the electric start if you can see that some of the teeth on the flywheel are stripped , you definitely need a new flywheel, parts diagram shows that it has a 'plastic ring' gear on the flywheel and doesn't show that the part is available seperate. Below is a picture of the assembly. About the running condition of the mower, I would start by removing the carburetor and cleaning it, get a common twist tie and remove the outer paper so you have a bare wire, use that wire to clean out the small hole in 'brass bowl nut' located on the bottom of the carburetor, then dry out with compressed air. The diagram below also shows the carburetor.
Sep 24, 2011 | Garden
I replaced the carburetor, spark plug, and put in new gasolone on a Toro Recycler (5 yrs. old) and it still won't start. The ignition is only one year old. Seems like I'm not getting any spark and the fuel...
Hi. Replace the air filter. Then use some starter fluid and an assistant. Spray some starter fluid into the air intake as you start it up and keep spraying so that it runs on the starter fluid for a few seconds until it really takes off. J.
If this does not do it then you will have to have the carburetor rebuilt as it has hardened gunk in it.
Aug 01, 2010 | Garden
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
! have a Troy built mower with a Honda engine, it quit running and will not start. I changed the spark plug, it ran for about one hour. Now the mower will not start.
Hello. If the gas has been sitting all winter, remove it with a siphoning bulb and put in brand new gas, not even gas that you have been storing all winter. Also, change your air filter. Finally get a can of starter fluid and a helper. While one person squirts a bit of starter fluid into the air intake [near the air filter] the other person starts it and use more squirts of starter fluid to keep it running. Joe
Apr 09, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
