Question about Welding Tools
I got my welder 2 days ago but the wire won't feed what do i do
    Top Expert:
  • Welding Tools Master
  • 49,314 Answers
Take it back for a warranty check
make sure that the lead is used in a straight position ( no bends or kinks in the lead)
Posted on Jan 01, 2017
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
luxur4
  • 92 Answers
SOURCE: welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Posted on Feb 20, 2009
SOURCE: NO WIRE FEED BUT WELDER CLICKING AS IF FEEDING
This could be caused by not enough pressure on the drive wheel. Try adjusting pressure as spelled out in you manual.
Posted on Apr 10, 2009
  • 71 Answers
SOURCE: I have a solar meg welder 2-175.The feed motor for
try changing the fuse if it has one
Posted on Aug 08, 2009
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
L bought a hobart 140 two days ago, welded about 10 feet of wire with it .now it only feed wire on three out of the five settings
Check the selector switch with an ohm meter. Unplug the unit, ground to chassis and probe the contacts while turning the switch on and off.
Dec 17, 2012 | Hobart Handler 140 Mig Welder
Century wire feed welder 83105 manual wire won't feed
check to ensure you have the right wire size.
check the tension adjuster.
replace liner
Oct 04, 2011 | Century Welding Tools
Difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
Jun 27, 2010 | Century 80GS Flux - Cored Wire Feed Welder
Wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
Jul 10, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Welding Tools Logo
665 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
