Question about Magnavox Televison & Video
How to diagnose and repair faulty Magnavox 32MD357B37 screen colors.
Magnavox 32MD357B37 screen displays wrong colors, dark should be light, pink should be blue, etc. This occasionally spontaneously reverts to normal picture, but is abnormal most of the time. My inspection of power supply board and main board reveals no abnormal capacitors or other abnormality. Audio is fine.
    Top Expert:
  • Magnavox Master
  • 75,581 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Jan 01, 2017
Philips plasma 63pf9631d/63 has a dark screen and the colors are wrong and it will blink from light contrast to dark. what would cause this
Bad component, bad connection, bad anything. Imposibble to diagnose from a distance whit this description of the symptoms.
Mar 05, 2015 | Philips 63PF9631D 63 in. Plasma Television
Projection television picture trouble
picture tubes are fine. just need to change out coolant
Oct 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Color Display on Panasonic Toughbook CF-28 is dull
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 01, 2009 | Panasonic Toughbook 28 Notebook
Pink color should be blue also flashing screen
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
May 22, 2009 | Acer Aspire One PC Notebook
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Screen turn into pink (light rise color)
if you have the skill for take off the cover,take off the metal shield and cables until you reach the CRT board,have a 100watt light on,a solder hot iron in one hand and a few rings of tin in the other, obviously take off the plug and left it over a few meters,and waited a few minutes to give some capacitors discharge time,.............it's easy !!! resolder the joints that like dark,mainly see the big transistors,(or IC)that have like rings on it's pins, and thats all. I tell you its easy okay then you have to "rebuild" your monitor back.
Jul 09, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
