My Mr Heater 125,000 kerosene heater lights but does not burn smooth. Lots of white smoke and builds up unburned fuel and drips/sprays out the front. Any help would be appreciated. Thanks, Steve
  • 3 Answers
SOURCE: air fuel mixture screw adjustment, forced air kerosene heater
Most ready heaters have a fuel pressure setting on the back of the heater near the fan. There should be two small plastic covers, looking directly at the back, the one on the left can be removed and a pressure gauge installed. The one on the right is slotted for adjustment of pressure. I think the correct pressure for that model is 3.0 lbs.
Posted on Jan 06, 2008
  • 14 Answers
SOURCE: Mr Heater MH75KT - won't start with diesel
If the MH75KT is the correct model, then it is a Kerosene only heater. Fuels, like oil and diesel all have different ignition points.
http://www.mrheater.com/upload/newsletter/70276_MH_HS_50_75_125_175_210KT_REV%20A.pdf
See page 3 of the manual.
Posted on Feb 04, 2008
SOURCE: Heater won't fire
place some kerosene into a small bowl, then place the fuel line drictly into the bowl . this way you can tell your getting good fuel. if no fire try removing the fuel filter. my filter was bad on mine i turned my upside down and it fixed it. its a in line filter.
Posted on Dec 23, 2008
tinytrees
  • 92 Answers
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Posted on Feb 05, 2009
heatman101
  • 43501 Answers
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
Photo resistive cell failure
Why does my 125,000 heater keep saying the photo resistive cell failure light keep blinking? I have know idea?
Mar 04, 2015 | Mr Heater Base Camp MH175KTR Forced Air...
I have a Mr. Heater 125,000 BTU contractor series shop heater and it started surging spurts of flame rather than run smoothly.
You may have contaminants in the fuel, such as water. Fuel that sits in gas cans can sometimes have condensed water in it. There may also be something that has clogged teh fuel flow.
Nov 26, 2014 | Mr. Heater MH125KT Utility
Spraying fuel out the front.
pressure to high turn down to 8.5 or 9 at least the mr heaters run at that for that size might have to clean the nozzel
Dec 01, 2013 | All-Pro Kerosene Garage Shop Heaters - All...
My ready heater 100,000 will run for app. 5hrs then flame out and blow smoke or unburned fuel the same several times pressure is right
If the heater continuously has a 5 hour run-time check to see if the fuel pickup tube goes to the bottom of the tank. If broken, cracked, or shortened the fuel will stop being picked up when air is sucked rather than fuel.
Feb 08, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Just replaced the ignitor on my mr heater because the old one was arching off the mounting bracket, now it fires for a second and puts out a large puff of smoke and blows diesel fuel out the front of it. I...
well for one it should have (kerosene) in it and not diesel. two you need to clean out the pump and lines as well . it should have a spray pattern, not drips. sounds like wrong fuel and or not enough pump pressure.
Jan 06, 2011 | Mr. Heater MH125KT Utility
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Pro 110, runs 10 min., blows white smoke ,shuts off
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
