Question about Gateway MX8711 Notebook
My gateway mx8711 don't turn on
Was working fine this morning nothing turns on power cord has the green lighton but wont turn on laptop please help i don't have any warranty.
My MX8711 is dead....won't,charge power cord is working- Won"t come on and the thing won't charge.Can you help me?
its probably the imput cus even if ur battery isnt taking a charge it should still come on if u have the cord in it
Apr 05, 2010 | Gateway MX8711 Notebook
My gateway mx8711 notebook shut down when I plugged in the power cord. The battery was charged but now it will not turn on with or without the power cord. Is there a fuse in the unit and how do I get to...
Seems like the Main power board is short circuit.And the cause was not the fuse, it's the unit, and maybe the power transistor, my suggestion is, take it to the expert, Service Center maybe or else to solve the problems.
hope it help you.
Feb 22, 2010 | Gateway MX8711 Notebook
Gateway MX8711 ran hot. Now will not power up
It sounds like the laptop has had some sort of thermal problem. Do you use it in a dusty/dirty environment? Did the laptop blower fan seem louder than it normaly was in the past? Any number of things (including age) could cause a laptop's fan to stop/work ineffectually and cause it to overheat.
Feb 10, 2010 | Gateway MX8711 Notebook
My MX8711 will not come on when I turn on the switch.
Your power adapter my be loose on the motherboard which would require soldering it back on.
To confirm if this is your problem plug your laptop in and press the cord in and press the power button continuously if it powers on thats your problem.
When pressing the cord in it may take a couple of different angles before you find the right one so press it in if that don't work press it in and lean on the left, then to the right, up, down etc.
I am experiencing this problem right now I have clamped my cord for a temporary fix.
Aug 27, 2009 | Gateway MX8711 Notebook
No power
Sounds like a motherboard issue, BUT first try fixing it with a few basics like:
reseating / swapping the memory
removing the hard drive and then powering up the machine.
Try those two first and then report back.
Jun 13, 2009 | Gateway MX8711 Notebook
Gateway M-6750 wont turn on suddenly.
Sounds like the motherboard may have gone bad on you. If your ac adaptor has a light on it, make sure it still has the light still illuminates when you plug it into a wall outlet. If it doesn't light up then it could be the adaptor but since you tried both just the battery and just the ac adaptor that would tell me the motherboard is bad. The only other option would be to resolder the dc jack on the motherboard back in place. It could be that the solder joints underneath the dc jack have cracks in them.
Jun 09, 2009 | Gateway M-6750 Notebook
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Battery Charging Gateway MX8711
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Gateway MX8711 Notebook
Gateway MX8711 Notebook Logo
143 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
