My wd-73c9 cooling fan does not come on and will not show a picture I put in a new bulb and I have sound
  • 295 Answers
SOURCE: my tv is new I plugged it in does it take awhile
If this isn't performing the way it did on the display floor. Please take it back. My thoughts is that the lamp already went bad.
I'm sure it's under warranty and I would get it replaced or repaired right away.
A/V Media Tech Guy
Posted on Dec 20, 2009
  • 5 Answers
SOURCE: Where does new bulb for picture go inside the TV?
The bulb is in the front of the TV. Remove the front lower cover by pulling oneside at a time. There will be a lable next to the cover for the light housing.
Posted on Feb 10, 2010
  • 979 Answers
SOURCE: for a while there was
Hello sir, hi, this requires that projector be checked, to fine the whining sound this requires disassembly, or have the unit checked for loose fan blades by a technician, and find that whining sound. If not replacing the bulb is useless, the bulb will always blow up.
Posted on Nov 13, 2010
  • 691 Answers
SOURCE: mitsubishi WD-73C9: my picture is
dim light check first make sure lamp was correct lamp for you model, most time it's worth buying lamp and enclosure to make sure lamp is correct then also it could be ballast problems.
Posted on Mar 14, 2011
  • 3 Answers
SOURCE: When i was turning the
not of course
Posted on May 15, 2011
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
There is sound but no picture
The board that connects to the bulb is the ballast. If it's bad then it won't fire the bulb or will cycle it on and off.
Jan 13, 2015 | Mitsubishi 915b403001 Lamp For Wd-65737...
Mitsubishi wd-73c9 73" dlp tv
Here's what the Manual says about light codes for this TV. See Picture of actual page from manual.
Apr 13, 2014 | Mitsubishi WD-73C9 73" DLP TV
Y wd-73c9 tv trns on no picture just a clicking noise when turned on
The color wheel spins at 10,000 rpm so there's a good chance that the bearings will go out, the heat and burnt on dust that gathers on the lenses and the class panels will be enough to cause mayhem with your color wheel. All the parts inside the light box need to be cleaned at least 1 time a year to keep it working properly. Much care must be taken when doing this it's very easy to destroy the wheel if it falls to the ground it's done. I suggest cleaning it over a carpeted area and keeping it on the floor while working. Place a piece of newspaper down over the carpet to keep fibers out of the area. Anything that gets sealed inside the area after cleaning will be burned onto the lenses and the problems will not be cured.
Feb 25, 2014 | Mitsubishi WD-73C9 73" DLP TV
Picture is dark. cleaned the lens and tried to adjust brightness
have you changed the bulb. over time it will go dark as the bulb burns out...
Oct 21, 2013 | Mitsubishi WD-73C9 73" DLP TV
Picture is dark
did u touch the lens or bulbs when u cleaned it? It could be a color wheel problem but i think u should try to reset light tunnel. Did it give you any warning? or did it just all of sudden go dim. I gave u a link to a trusted YOUTUBE tech.. i use his work all the time.
See if any blink codes come up if u disconnect a bulb..good luck
chad man
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Recentley my tv just turned off. I heard a buzzing sound which happened the 1st time my bulb went out. So I ordered a new one. When the new one was put in it worked for 5 minutes then turned off and...
This could be a couple of things. Look at the cooling fan and be sure that it can spin freely. If it is stuck, the buzzing could be the motor trying to spin the fan. Other than that, the ballast could be failing as well. This is the part that "fires" the lamp. Examine the fan first and let mw know what happens.
Jul 22, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
