Question about Vehicle Parts & Accessories
Display on Mazda bt-50 not working. No time ,no date ,no climate control display.
2013 XTR highrider
    Top Expert:
  • 79,865 Answers
You need to remove it and have an approved Mazda electronics repair station fix the display
Posted on Jan 01, 2017
Mazda bt 50 2013 ,batte going flat, was every 8 9 days then every 3to4 days now every day, outo elect, back to Mazda ,they say not there problem, Murrey Mcintosh ,
batteries have no guarantee from the dealer
indicates a failed cell
have a load test done and if bad get a new battery
Dec 21, 2017 | Mazda Cars & Trucks
Mazda BT 50 - 2012 Model - Just out of warranty. Trrrrrrt sound coming from dash from time to time (last two weeks it started), even while just switched on, engine not running yet, aircon also off.
I think you should go for manual first after that it will be easy for u to solve your problem. I had visited this site past 2 months before for my vehicle and find it quite helpful may be you will also get something useful here
MAZDA BT 50 BT50 2011 2014 WORKSHOP SERVICE REPAIR MANUAL
Nov 17, 2017 | Mazda Cars & Trucks
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Manual for Mazda BT 50 I can not rember how to re set the the frigde ?
  1. Mazda BT-50 - CarsGuide
    www.carsguide.com.au/mazda/bt-50 CarsguideBT-50 Car Showroom Online: Discover BT-50 Pictures, Videos, News & Reviews: ... My 2007 Mazda BT-50 ute had a very smelly clutch problem after rever.
Jul 12, 2015 | Mazda Cars & Trucks
What is the difference between the Whistler XTR 265 and the xtr438
The XTR-438 has Text display (vs. the XTR-265 Icon display), filter and TFSR modes (TFSR = Traffic Flow Signal Rejection). This mode helps reduce the alarms from traffic monitoring transmitters.
Feb 01, 2015 | Whistler Vehicle Parts & Accessories
Mazda bt 50 problems
If you still have 25 lts still left in the tank and get it out. I would think the pick up tube is bent or cracked and no longer at the bottom of the tank.
Jun 01, 2014 | 2011 Mazda BT-50 L-Cab
Change in display
Go to options - display - date/time format. Change it to short
Nov 27, 2013 | Panasonic KX-T7731 Corded Phone
Tengo una mazda BT-50 y la luz indicadora RFW LOCK no se apaga??
tengo un mazda bt-50 pro cabina sencilla y el radio se me desconfiguro tengo q poner tres codigos de cuatro numeros cada uno q me ayuden xfaaa diganmee esos codigos se les agradece
Feb 25, 2012 | 2005 Mazda B-Series
Climate control display INOP
dude check the fuses in the bottom left of driver side , i had that issue and just changed the radio one to a bigger fuse and it turned right back on , it was strange ,
Jul 11, 2008 | 1995 Mazda Millenia
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
