Question about Dryers
Will a dryer still work lying sideways? - Dryers
    Top Expert:
  • Dryers Master
  • 75,822 Answers
Maybe, try it.
Posted on Jan 01, 2017
Poulan 306 chainsaw
Drain the fuel from the tank and inspect the fuel line inside for flexibility and overall condition. If the filter doesn't flop to the lower side of the tank when the saw is turned, the filter won't be lying in fuel to be picked up and the saw quits. Use original type rubber line for replacement, not plastic.
May 10, 2010 | Garden
How do i remove the front of the dryer???door opens sideways not up and down
After opening the door,you should see four phillips head screw going vertically up into top.Remove screw and lift upward
Sep 29, 2009 | Whirlpool LER3624JQ Electric Dryer
Dryer quits after being used for a while and won't turn back on
It is overheating.
You are luck it puts out any heat.
You didn't say if it was Electric or Gas?
If electric, the the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU. Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on or shut off prematurely (Gets too hot too quick).
If Gas, the thermocouple that tells the CPU that the 'heat is on is 'lying' or the sensor that tells the CPU the Air movement is OK' is bad.
My dryer wouldn't heat because a thermocouple in the exhaust pipe was lying - stuck ON and telling the dryer it was already hot enough. ;-) and my Furnace turned on and off for 10 minutes b/c the airflow sensor was jammed.
If you do the troubleshooting, do NOT forget to unplug first!
Mar 27, 2009 | Dryers
Kenmore dryer wont work
Electric or Gas?
If electric, the element is gone or a fuse blew or the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU.
Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on.
If Gas, the pilot isn't lit or the electronic ignition isn't firing or the gas supply valve is bad/stuck or the thermocouple that tells the CPU that the 'heat is on is 'lying' or the sensor that tells the CPU the Air movement is OK' is bad.
My dryer wouldnt heat because a thermocouple in the exhaust pipe was lying - stuck ON and telling the dryer it was already hot enough. ;-)
Dryer does not put out any heat
Electric or Gas?
If electric, the element is gone or a fuse blew or the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU. Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on.
Mar 26, 2009 | Dryers
My dryer stopped heating. Everything else seems to work. It still runs, but only feel cold air.
Electric or Gas?
Help!
problem would lie on convergence board, usually two big STK ics and resistors
Nov 14, 2007 | Zenith IQB50M90W 50" Rear Projection...
Dryers Logo
24 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
