Question about Craig Televison & Video
What is the code for the Craig digital converter box to access channels
    Top Expert:
  • Craig Master
  • 76,132 Answers
The remote that comes with your converter box will not work with your VCR/DVD recorder. You'll need a seperate universal remote - See more at: http://www.dtvusaforum.com/threads/3309-I-need-help-to-find-the-CODE-for-CRAIG#sthash.60Q0ehJJ.dpuf
Posted on Jan 01, 2017
  • 14 Answers
SOURCE: Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Posted on Oct 23, 2008
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
  • 15 Answers
SOURCE: Can't view my digital channels
Get an outdoor antenna. Digital signals very rarely reach indoor antennas unless you are within ten miles of the signal origin.
Posted on May 16, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
Posted on May 18, 2009
gopakumarg43
  • 74211 Answers
SOURCE: I need the security code for Panasonic Digital Converter Box
Download the user manual to your converter box from internet. Click here to download it. It will have all details you want.
Posted on Apr 21, 2012
Testimonial: "Managed to sort out the problem.....Many thanks. "
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jan 11, 2017 | Televison & Video
ONN universal remote model #ONA13AV269 , I need the codes for Craig brand digital converter box .
If your ONN universal remote has a code search (or equivalent function), you can use it to search for a suitable code. Bear in mind that digital converter boxes often use unique codes to prevent conflict with the TV remote.
Jun 11, 2014 | Televison & Video
I have a craig analog to digital convertor box model cvd508 and cant find a universal remote to program it.ive used 3 already.help!!!
Converter boxes usually use uniquely coded remotes. You will not have much luck without getting a replacement remote intended specifically for your converter
Aug 30, 2013 | Televison & Video
I need the PHILIPS universal remote codes for a CRAIG DIGITAL TO ANALOG BRODCAST CONVERTER MODEL CVD508
042/ 053. These are the codes to check with Craig. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 19, 2013 | Televison & Video
What is the universal remote code for a CRAIG DIGITAL CONVERTER MODEL CVD508
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter". Setup code list and setup proceedings to most popular brand remote controls, including Philips SRU models are there.
FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Craig
Mar 16, 2009 | Polaroid FLM-3232 Television
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Televison & Video Logo
Top Craig Televison & Video Experts
Raj Patel
Henry  Thomas
Henry Thomas
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
