Question about Vax Vacuums
I have a replacement hose for a vax 2000 vacuum cleaner. How do I fit it to the old end piece?
SOURCE: Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Posted on Feb 03, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
SOURCE: I can't put my vax vacuum cleaner back together
Contact Vax customer service, they are very helpfull!
Or use this link to find your local service agent: http://www.vax.co.uk/support/service_and_support.php
Hope this helps.
Dina
Posted on Dec 22, 2008
SOURCE: My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Posted on Apr 23, 2010
nonontech
  • 4737 Answers
SOURCE: instruction manual for a vax
There is no specific manual available for this model, but you can get the Vax V series manual and technical reference guide.
1. Vax multifunction vacuum cleaner user guide (pet)
2. Vax multifunction vacuum cleaner user guide (family)
3. Vax technical Draw Reference (V11 page No.2)
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 29, 2010
How can I download user manual for Vax 2000 wet and dry carpet cleaner ?
Try Googling (vax)(2000)(manual) without parens.
Jun 17, 2017 | Vax Vacuums
My vax rapid carpet cleaner no suction filter is fine
If the vacuum is still functioning, the hose is most likely clogged. Disassemble the vax and unclog. Make sure you drain before disassembling. If possible do this outside.
May 16, 2016 | Filter Vacuums
Www vax co uk support
take apart
put together
do this few times, and with every time a piece left out, still workingyou will have two working vaccums
Apr 22, 2013 | Vacuums
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
Jul 15, 2012 | VAX Appliances Vacuums
Mannual for a vax 2000 vacum cleaner
Below can be found the downloadable user's manual for the Vax 2000 UR vacuum. If that's not it, check the manuals on the second link.
http://www.vax.co.uk/downloads/pdf/u90-vu-series_user_guide.pdf
http://www.vax.co.uk/support/resource_centre.php
Jan 09, 2011 | Vacuums
Hi i have a vax swift complete 1800 watt,it is not picking up and the brushes are not moving they are also tough to move by hand what could this be
Possibly brush needs to be removed , cleaned , brush bearings lubricated, and new belt or oring belt needs to be fitted.
Dont do it yourself unless mechanically minded.
Ring up vacuum cleaner place.
Sep 12, 2010 | VAX Appliances Vax X5 Bagless Upright...
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Hope this helps.
Dina
Sep 21, 2008 | VAX Appliances Vacuums
Vacuums Logo
27 people viewed this question
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
