Question about Crafts & Hobbies
For cricut air 2 can I outline a printed image before it cuts
4 Suggested Answers
albertv29
  • 87 Answers
SOURCE: double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Posted on Jan 14, 2009
  • 9 Answers
SOURCE: need to update firm ware on cricut expression so i can use sure cuts alot could not find at cricut.com
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
balboul@gmail.com
Posted on Jul 05, 2009
CricutAddict
  • 13 Answers
SOURCE: The cricut does not cut through the paper, it only
Yes, there are three rollers that one adjusts your size of the image you are cutting that is on the right hand side of the machine. The other two are on the left side of the machine. The top one is your speed control and the bottom is your pressure. I would move it up to medium when cutting with cardstock or even up to high if it is thick cardstock. Hope this helps, any further questions feel free to ask me.
Posted on Mar 25, 2010
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    My cricut mini wont cut. an error appears and says that the images arent on the mat properly and will be skipped
    I am having this problem also. The image i wish to cut is well inside the 12 inchs. Hope someone has the answer
    Oct 30, 2016 | Crafts & Hobbies
    One or more of your cut images are not positioned entirely on the mat, They will be skipped
    Just follow the steps given at this link, and your cutter should begin to cut again. I just tried it and my cutter is back cutting. Cricut Craft Room Troubleshooting Cricut Help Center
    Aug 01, 2016 | Provo Craft Cricut Mini Electronic Cutting...
    When using a design in Cricut Craft Room, and select cut, my Expression 2 begins, but does not complete, the cut. The arm moves to the paper and then makes a croaking sound and then nothing.
    Search cricut.com for support faq go to expression 2 search format and reset. Watch the video on format and reset and do as it says. Calibrate when it's finished. If this doesn't work re download ccr after deleting it from your computer.
    Jan 10, 2016 | Provo Craft Cricut Expression 2 Electronic...
    How do I use the Artbooking cartridge on the cricut design studio?
    Cricut design studio is no longer supported by Cricut but if you mean Cricut Design Space then this is how you do it. Open and sign in to Design Space select insert images and in the box on the right select my Image sets and then type in Artbooking. Artbooking cartridge will then come up for you to select what you want. all images come onto the mat at 2.5 inches they havent fixed this yet so you have to resize your images. If you want to download the image numbers from the artbooking book which go with design space go to http://thenon-craftycrafter.blogspot.co.nz/p/image-codes.html and download the artbooking book from this lady please join her blog and leave her a message as she does a lot of work all of which she does for free. Also if you youtube cricut design space. or go onto design space in cricut.com
    Aug 20, 2014 | Cricut Expression Cutting Machine
    My Cricut Expression is not working. When i pressed the cut point on the screen all it did was a loading screen and would not cut. What should i do?
    fruchey10 you have not given me enough info to help you but if you contact me I will try to work out a solution to your problem. exactly what are you doing ie do you have images loaded onto the image queue. contact me via my website OhSoManyCrafts
    Feb 02, 2014 | Cricut Expression Cutting Machine
    Cricut expression 2
    Cricket is hung up on the first small cut and keeps repeating that same cut over and over
    Aug 09, 2012 | Toys
    The cricut does not cut through the paper, it only scores it enough to see the outline of the image to be cut. I have checked on line and the blade housing is installed correctly. Does the cutter have a...
    Dec 30, 2009 | Provo Craft Cricut Disney Font Cartridge
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    Crafts & Hobbies Logo
    362 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Debbie
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
