Question about Pentair Pool & Spa
I have an Pentair Easy Touch 8. I push the Filter button on the outdoor panel. The green light is on but my filter does not turn or start on. I ran the Self Test and no error code. Any idea's?
    New Friend:
  • 60 Answers
This could be a number of issues....
Pump motor could be bad, capacitor could be bad, relay could be bad, or a circuit board issue.
Check the breaker for the filter pump, turn it off and back on.
Press the reset. It tim on the outdoor control panel and wait for a few minutes as it reconfigures.
Then try to turn it on again.
If that doesn't work
If you know how then test the leads at the motor once you have pressed the filter button.
Otherwise you probably need a professional to check on it.
  • 61 Answers
Sounds like one of the relay's has gone bad inside the box. If your lucky you can move the wires to another relay if there is one available. Make sure you move the top wires too, not just the 4 bottom wires, or you will have to do some reprogramming.
Posted on Apr 04, 2009
  • 128 Answers
SOURCE: under water pool light not coming on
Check the GFI on the side of the control panel.
Posted on Aug 30, 2009
  • 64 Answers
SOURCE: Whisper Flo model WFE 6
Possible bad motor. You would need to test voltage at the motor connections with a multi meter. If the voltage is correct, then the motor or start capacitor is bad. If the proper voltage is not correct, then you would need to look upline in the electrical system to find the problem
Posted on May 20, 2010
  • 310 Answers
SOURCE: I have a Pentair Easy
Here are the links for operation/users/installation manuals. Hope this helps
Posted on Jan 14, 2011
SOURCE: Pentair Easy Touch 8: Im getting
Getting the same thing- any solution
Posted on May 24, 2011
Can you hook up a jandy 4-button spaside remote to the pentair easytouch controller?
I've installed dozens of Pentair ez-touches. Call Pentair and ask them. I don't think you can, but I could be wrong. Plus, in my opinion, Jandy isn't a very good brand anyway. Just get the one that is supposed to go with the ez touch. It's easy to run and program and you already know it's going to work because it was made for the ez touch system. You'll save yourself a lot of headaches by not trying to save a couple of bucks.
Feb 28, 2014 | Pentair Easy Touch Indoor Control Panel...
I can't get my new Pentair easy touch indoor remote to sync with the easy touch control panel. When I select wireless address search on the remote (after sending the signal from the control panel), it...
First off go to power save and set it for 5 minutes. This will give it plenty of time to find wireless. If it still doesn't find it then you have a bad transceiver.
Aug 31, 2013 | Pentair Easy Touch Indoor Control Panel...
My Pentair easy touch control panel quit working. I power it down with the breaker power it back up and the screen comes on for a bit and I can even turn the filter on but then the screen goes blank and...
I would call the Pentair technical support at 800-693-0971 number and they should be able help determine what to do next.
Pease let me know how this works out. Thank you.
Aug 31, 2011 | Pentair Easy Touch Indoor Control Panel...
Pentair Easy Touch remote lost sync with the outside unit. Have tried resyncing a dozen times, per the manual, tried hitting the reset button and then resyncing...nothing worked. I removed the cover on...
Try turning the whole system power off at the main house panel, wait a minute, turn power back on, then go to the pool panel and reset communication as per manual instructions. This worked for me.
Sep 25, 2010 | Pentair Easy Touch Indoor Control Panel...
Water temperature thermostat misread
You most likely have a bad water temperature sensor. Replace the water temperature sensor that is probably near the discharge side of the filter pump. That should take care of the problem.
Oct 17, 2009 | Pentair Easy Touch Indoor Control Panel...
Under water pool light not coming on
Jun 14, 2009 | Pentair IntelliBrite Pool Light :: 120V -...
Pool & Spa Logo
47 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
