Question about Refrigerators
I have an Pentai East Touch 8. I push the Filter button on the outdoor panel. The green light is on but my filter does not turn or start on. I ran the Self Test and no error code. Any idea's?
Slinteriors
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
  • 99 Answers
SOURCE: Chevrolet 2500 Not Running, May Be Fuel Filter Sensor
if it dont have good compression it will not start check the comp and make sure there no water in oil if fuel pressure is low it will not pop the injector open try some starting fluid
Posted on Jan 26, 2009
  • 12 Answers
SOURCE: ERROR CODE 2000-0142
Hard drive is failing. Reseat hard drive cables. If it does not work, have to replace hard drive. probably damage from overheating or powersurges.
Posted on May 15, 2010
  • 356 Answers
SOURCE: confidence check error code 1332 device
Hi there!! It seems like you have a fried hard drive. Check the warranty of your system and have the hard driver replaced.
^_^
Posted on Jun 03, 2010
  • 74 Answers
SOURCE: Front panel beeps when I push any button or
possible bad dispenser board
Posted on Nov 17, 2010
I have an Pentair Easy Touch 8. I push the Filter button on the outdoor panel. The green light is on but my filter does not turn or start on. I ran the Self Test and no error code. Any idea's?
this could be a number of issues....
Pump motor could be bad, capacitor could be bad, relay could be bad, or a circuit board issue.
Check the breaker for the filter pump, turn it off and back on.
Press the reset. It tim on the outdoor control panel and wait for a few minutes as it reconfigures.
Then try to turn it on again.
If that doesn't work
If you know how then test the leads at the motor once you have pressed the filter button.
Otherwise you probably need a professional to check on it.
Dec 31, 2016 | Pentair Pool & Spa
Tip
How to Reset Your Air Conditioner Filter Light
<span style="font-weight: bold;">Cabin Air Conditioner:</span><br /> <ol> <li>Press and hold down the Off button for 4 seconds.</li></ol><span style="font-weight: bold;">Carrier Air Conditioner:</span><br /> <ol> <li>Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Daikan Air Conditioner:</span><br /> <ol> <li>Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Frigidaire Air Conditioner:</span><br /> <ol> <li>To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.</li></ol><span style="font-weight: bold;">GE Air Conditioner:</span><br /> <ol> <li>Turn the air conditioner OFF and unplug it.</li> <li>The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.</li> <li>After cleaning, replace the filter and plug the air conditioner back in.</li></ol><span style="font-weight: bold;">Honeywell Air Conditioner:</span> <ol> <li>Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)</li> <li>Press the Run Program button.</li></ol><span style="font-weight: bold;">Kenmore Air Conditioner:</span><br /> <ol> <li>To reset the filter indicator, press and hold the filter reset button for 3 seconds.</li></ol><span style="font-weight: bold;">Lexus Air Conditioner:</span><br /> <ol> <li>Without having foot on the brake, press the Start button twice to get to the IG-ON position.</li> <li>Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.</li></ol>or<br /> <ol> <li>Turn the engine switch to IG-ON mode.</li> <li>Push and hold the A/C OFF button for more than 4 seconds.</li></ol><span style="font-weight: bold;">Lexus 2008 Air Conditioner:</span> <ol> <li>Push the "INFO" button & touch "Maintenance".</li> <li>Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.</li> <li>Input the Notice of Date: The next maintenance date must be input.</li> <li>Now input the Notice of Distance: The driving distance until the next maintenance check.</li> <li>Delete: To cancel the date and distance conditions.</li> <li>Reset: To reset the date and distance conditions.</li> <li>Touch "OK" The screen returns to the "Maintenance screen.</li></ol><span style="font-weight: bold;">Lincoln LS 2001 Air Conditioner:</span><br /> <ol> <li>Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.</li> <li>Watch the system check when it goes to A/C filter hit the reset button.</li> <li>Hold down the reset button to confirm.</li></ol><span style="font-weight: bold;">Lincoln LS 2003 Air Conditioner:</span><br /> <ol> <li>Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.</li> <li>Press and hold the RESET control to set to 100%.</li></ol><span style="font-weight: bold;">Lincoln LS 2005 Air Conditioner:</span><br /> <ol> <li>Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.</li> <li>Press the "Status" button above the radio until the system display changes to "AC Filter."</li> <li>Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."</li></ol><span style="font-weight: bold;">Maytag Air Conditioner:</span><br /> <ol> <li>Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.</li></ol><span style="font-weight: bold;">Whirlpool Air Conditioner:</span><br /> <ol> <li>Push in the filter reset on the remote using a straightened out paper clip or similar.</li></ol>or<br /> <ol> <li>On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.</li></ol>or<br /> <ol> <li>After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.</li></ol>
on Jun 17, 2011 | Heating & Cooling
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Filter light status
Please verify the model number for your fridge, as the description shows a Frigidare 24" dishwasher.
With the model number and you providing the different buttons on the front panel, I can provide you with the button sequence to push and hold to reset the filter light.
While waiting for the needed info for an exact solution, you can try this:
If you have a "light" and "lock" button, push and hold them together for several seconds, the filter light should go off or change back to green.
If not, please provide me with the brand and model number for your fridge so I can give you the correct procedure for resetting the indicator light, by responding back with a "comment".
Hope you find this Very Helpful and best regards!
Aug 18, 2009 | Frigidaire Professional Series 24 in....
Aqualink RS6 all lights on control panel lit and won't work
I' m having the exact same problem, where the panel lights up and is non-responsive. Did you ever find a solution?
May 21, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
AQULINK CONTROLLER WILL NOT TURN OFF FILTER PUMP
Sounds like one of the relay's has gone bad inside the box. If your lucky you can move the wires to another relay if there is one available. Make sure you move the top wires too, not just the 4 bottom wires, or you will have to do some reprogramming.
Mar 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I can't find where my water filter is. Model number GC3PEXN500
That model looks like a Whirlpool, I am very familiar with their set ups
We put the filter in two places
Commonly its right under the freezer door in the grille area, you will see this big knob shaped item, turn this from east to west to north to south (counter clockwise a quarter turn) then pull the filter out, if its is a push button the button is usually triangle shaped and right next to the filter. Push it in till you here a click
The last two places in the upper right corner of the freezer OR the refrigerator section, if not in any of these three places you dont have one
May 02, 2008 | Refrigerators
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Mar 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
