Question about Ovens
I have a Beaumark stove and unable to set the time once the power fails, the clock works but not in time
4 Suggested Answers
SOURCE: beaumark stove
The bottom element quit working and whats up with that!!!It is not burnt out we checked for that
Posted on Nov 13, 2008
barkencoa
  • 3463 Answers
SOURCE: Stove with LED clock display, need to be set
Try holding 2 buttons at a time and whilst doing so, press the button with time on it or clock face, or just keep trying different buttons until myou get the right combination, stick with it you will get it to go.
Posted on Dec 15, 2008
  • 250 Answers
SOURCE: How do I set the clock time on Stoves Cooker
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Posted on Aug 15, 2009
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 | Ovens
No power to the double oven but the hob still works
The double oven will only work if a time is set on the clock. Any time will do, you just have to set a time. The grill/top oven is independent of the clock. If the clock is faulty espare can sorce them for you.
Mar 27, 2011 | Stoves 720EF Electric Double Oven
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
Can not re set time
Are you trying to reset the timer or the Clock? It's a bit different on each stove, but usually if it's the clock, you press the Clock button TWICE, the time will then begin to flash on and off. then press the + or - sign to increase or decrease the time. When you have gotten to the time you desire, PRESS the Clock button ONCE more. The time will be set, & then you should be all set :).
If it's the KITCHEN TIMER, Press the Kitchen Timer button ONCE, the timer will start flashing. It will usually flash all 0000's. Press the + sign to add minutes, then Press the Timer Button ONCE again, it will be set to the amount of time you added and will beep once the time runs out.
Disclaimer: This instruction is primarily for the General Electric Stove. If you state your specific model, I could be more specific.
Nov 12, 2010 | Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Our Chef Sapphire Clock & Oven stopped working suddenly after a power failure overnight. Are there any fuses to be found inside, or any other suggestions please. The stove top is fine and all 4...
This oven needs the time set after a power failure. The LED display will read HELPME and there is a small knob on the left side you need to turn it to set to change the time and use the second knob from left side to + and once done leave the knob on manual. The oven can be timed to turn off but it the time is not set on it the oven and stove do not work.dux_training.jpg
Aug 29, 2010 | Ovens
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Nov 11, 2008 | Stoves 720EF Electric Double Oven
Beaumark stove
I also don't have a manual, but work on computers so tried some buttons and they did the trick.
On the left hand side is the button that has Mode, and then a series of buttons.
On the right hand side there is a series of buttons, and one looks like heat coming from the bottom. Turn this button to that setting.
On the left side, press the mode button, and then press the button that looks like a thermometer. This is the mode for setting the temperature of the over.
Beside the display windows, there is knob that looks like a dial on an analog clock. Turn this dial until the temperature you want appears.
Oct 23, 2007 | Ovens
Ovens Logo
85 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
