Question about Schwinn Cycling
From research on Schwinn Frontier GS, it appears my bike is all 1997 frame and components with a 1996 paint job and seat. Is this possible and does anyone know where this bike was manufactured?
I have a Schwinn Frontier GS, serial number 3226.
  • Schwinn Master
  • 1,192 Answers
In 1997 it would have been manufactured overseas, not really important where. Neither is the exact date important, but generally bikes models go by the paint job, as component specs can change.
Posted on Jan 01, 2017
How do I know what model Schwinn bike I have?
The model is written on the frame or on the chainguard. If the frame has been repainted the model doesn't matter much, as any value has been severely reduced, especially if it was not a professional paint job.
Dec 24, 2016 | Schwinn Cycling
SL040733 is the serial number. How do i know what year it is?
if you find a shop selling them they should know the year by the serial number or the paint job on the bike, they even might have a catalogue with your bike pictured.
May 12, 2016 | Schwinn Womens Frontier
I have schwinn stingray bike but the frame serial number doesn't appear to be a schwinn number. would JAK 13245 be a schwinn serial number
It doesn't appear to be a Schwinn frame. I suggest that someone has switched out a phoney frame, added Schwinn parts and sold it as a genuine Schwinn. Schwinn date codes are available on-line.
Oct 12, 2014 | Cycling
I have a Schwinn women's 21 speed Frontier. Frame in purple serial #0378. I wanted to know the year and specs. On it? Thank you!
First thing, is headbadge black and red? Does it say it was made in China, either on the headbadge or somewhere else on the frame. If so, the bike has no value as an antique bicycle. If its in running condition, tires hold air, brakes work and gears shift its about a $60 to $ 75 bike
Sep 22, 2014 | Schwinn Frontier 21 Speed Mountain Bike...
My schwinn S2742 bike seat detached from the bike.
if you could post a picture of the bike seat area it will be easyer to solve your problem
Jun 20, 2012 | Schwinn S2742 Coronado Men's 26" Alloy...
I can't get the bike seat stem to come loose
I'm going to assume you that when you say, "bike seat stem" you mean "seat post". I'm also going to assume that the bike frame is made of steel and the seat post is most likely chromed steel.
What most likely is the problem (absent of more details) is that the seat post has rusted to the inside of the frame. If the bike is stored outside this is a very common problem on less expensive bikes.
I have never heard of a bike manufacturer putting any kind of paint or other anti-corrosion inside of the bike frame to prevent rust.
You can try spraying a little "Liquid Wrench" or WD40 oil on the seat post where it inserts into the frame. Let it sit over night and then tap it with a mallet to try to break the rust free. Use a pair of Channel Lock pliers to get a bite on it and see if you can twist it out.
On a steel bike the very last resort to use, if you by all means have to have that seat post out, is to apply heat to it, with a propane or oxy-acetylene torch. This will probably destroy the paint job and weaken the seat post.
If the bike frame is aluminum, you can get something similar to galvanic corrosion and this can seize the seat post in the frame. The remedy is the same as with the steel frame (but excessive heat and easily melt aluminum very quickly and leave a puddle of molten metal on the garage floor). If the frame is carbon fiber and the seat post is aluminum, carbon and aluminum don't like to touch each other and they will start a natural chemical reaction of corrosion which could cause the two to stick together (don't ever use a flame on a carbon fiber bike, it would be the end of the bike and just plain stupid). Anytime aluminum touches carbon or titanium an anti-seize compound should be applied to the parts.
Once you have the seat post removed, use your finger to wipe grease inside the seat tube and on the seat post before reinserting it and you won't have this problem again.
Aug 30, 2010 | Bike Extreme Lite Youth Shoulder Pad
Frontier GSX Women's Mountain Bike: what is proper way to remove and re-install the qu...
Unhook the front brake, loose the quick release level and push the tire off the fork. reverse procedure to install.
May 16, 2010 | Schwinn Frontier GSX Women's Mountain Bike
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Cycling Logo
304 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
