Question about The Toys
How do you get the props off the Air Hogs Speeder Bike Drone. I cant seem to get them off. Thank you.
My drone is not taking off. It seems one of the wing is not spinning properly. How to fix it?
Order a new motor for that prop. I have had this happen to me before. Just make sure to replace with the same type Electric motor. "same specs" I learned that the hard way. As my replacement motor had a lot more "torque then the original motor" that came with my drone. It's an easy fix that isn't costly.
Aug 15, 2016 | Cars & Trucks
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Apache havoc micro... can not trim the helicopter it spins counterclockwise.
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Mar 02, 2010 | Air Hogs Havoc Heli Helicopters
Toys Logo
63 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
