Question about Panasonic Heating & Cooling
Hi i have a Panasonic aircon and the timer light comes on and the unit shuts down i done the error check and it says H00 whats wrong with it and how do i fix it
    Scholar:
    New Friend:
  • 149 Answers
H00 is code showing the system has no memory of an error so you could try turning the power off for 15 minutes then back on and see how it goes. Power supply fluctuations can sometimes make Panasonic A/C's do funny things. If the fault recurs, you will have to get a tech to diagnose.
Posted on Oct 02, 2017
SOURCE: Panasonic reverse cycle aircon.
Found the codes are printed inside the air conditioner.
F33 ---01. = locked up compressor.
Cannot fix this problem myself, will have to engage a serviceman.
Stan.
Posted on Jul 17, 2008
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
  • 586 Answers
SOURCE: I have a panasonic split
Hello there,
When your air conditioner comes up with the error code, H00, it simply means there is not abnormality or problem with the air conditioner and it is meant to run its operation normally. The airconditioner does a self check and then displays a error code on the screen for you to be able to tell where the problem is from. Some times there could be a fault somewhere in the unit,but the self check does not detect it, that is why it comes up with the error code H00. Which means there is no problem and the air conditioner should be running just fine.
Adjust the temperature to see if it will work. If that does not solve the problem. Since it is not detecting the problem and sending its code to the screen and just saying it is under normal condition. I will advice you carry out a general servicing on the panasonic split unit air conditioner.
To do that, Please run through the installation and servicing manual, or you can get an air conditioner professional to run this servicing for you.
http://www.lmg.nu/fileadmin/support/servicemanualer/s_ce7_9_12hke.pdf
Wish you all the best on this. Elect_Comp
Posted on Sep 17, 2011
SOURCE: my panasonic ceiling aircon model cs-d24db4h5-1 timer light on and not cold.
is your filter dirty? i could see it stoping if the filters dirty. check the filter and if that is not it take it into a shop or send it in. if it cost's more to fix it just forget about it and get a new one good luck.
Posted on Jun 24, 2012
  • 5 Answers
SOURCE: Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Posted on Dec 10, 2014
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
(continuously for 4 seconds) will be heard. If no codes are
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
Panasonic beat pump
Possibly, check error codes for problems:
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display. Note: Display only for "- -". (No transmitting signal, no receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
May 31, 2015 | Panasonic Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
LED will light up again.
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
unit.
pressing the CHECK button continuously for 5 sec-
30 seconds.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Panasonic cs e9nkr aircon. Shuts down timer continuously blinks. Checked for fault codes h00
I haven't got the service manual for this but the error codes should be on a sticker behind the front cover. Take that of and it will guide you to the fault.
Feb 19, 2015 | Panasonic Heating & Cooling
Hi my panasonic CS-PS18NKQ is not working,timer indicator keep on blinking.
When you have the error code, you can narrow down the problem.
Feb 04, 2015 | Panasonic Heating & Cooling
PANASONIC CS-CU E24PKR fault code H00
H00 No abnormality detected - Normal operation
You may have a problem with the outdoor controller, the indoor controller or both. Power outages can do some strange things to the electronics. Turn the A/C isolator off for five minutes and back on again to be sure the problem is still there. You could also try this:
• To clear memorized error (Protective operation) status
after repair:
1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
Jan 31, 2015 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
David
    in IC memory.
  1. 1 Turn power on.
    unit.
Dec 10, 2014 | Panasonic Heating & Cooling
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
Hi, Our Panasonic split system is not working....the timer button just flashes. In the manual it says to hold down the check button for 5 seconds, then hold down numbers 1 and 2 until it beeps to get an...
Diagnosis display = H00
Abnormality / Protection control = No abnormality detected
Abnormality Judgment = Nothing
Emergency operation = Normal operation.
Your unit is under timer set up. Please keep remote towards indoor sensor press timer on and change to 00.00 . If you get beep sound, switch off a/c and then restart.
Jan 11, 2011 | Panasonic Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Heating & Cooling Logo
128 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
