Question about Radio Communications
Cant delete old frequencies
I hold down 2, 9, and hold to erease and scanner wont turn on
5 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: how do i reset frequencies on a scanner
You listed your question in the PRO-2096 section, so this response applies to that model. If you have a different scanner, please let us know the make and model.
The PRO-2096 is an advanced scanner capable of monitoring both single frequency conventional systems and advanced trunking radio systems. Programming methods are detailed and lengthy and cannot be reproduced here. For specific programming instructions, please see the scanner's operating manual, which can be downloaded/printed here:
http://pdf.textfiles.com/manuals/SCANNERS-F-R/Radio%20Shack_PRO-2069%20Wideband%20Scanner-Reciever_Manual.pdf
If you have questions regarding a specific feature or problem with the scanner, please let us know.
Posted on Dec 20, 2009
  • 211 Answers
SOURCE: Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Posted on Feb 20, 2010
BillB-SA
  • 2761 Answers
SOURCE: i cant seem to be
Frequencies in the range you mention may be part of a trunked system that your scanner cannot follow, but you can still enter and monitor the frequency. Yes, your BC340CRS will handle frequencies with up to five decimal places, as long as the last two digits are 25, 50, 0r 75 (see page 16 of the BC340CRS Owner's Manual). The best programming instructions for your scanner are also in that manual. If you don't have a copy, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Posted on Mar 01, 2011
  • 3289 Answers
SOURCE: Regency R1077 base scanner can
Press "Manual", then press digit key ("0/10" thru "9") that corresponds with the channel to be changed ("0/10" = ch10). Next, press the digit and decimal point keys to enter the frequency in megahertz (Mhz) to be stored in the channel. To store 453.100 Mhz in channel 2, you would press "Manual", then "2". Press the following keys in order: "4" "5" "3" "." "1" "0" "0", followed by pressing the "Enter" key. Repeat this process for up to 10 channels.If you wish to clear unused channels, you should be able to select the channel, then enter "." followed by the "Enter" key.
This scanner will only accept frequencies between 30.000Mhz and 599.999 Mhz. Attempting to input frequencies outside this range will result in an error message.
I hope this helps and good luck! Please rate my reply. Thanks.
Posted on Jul 11, 2011
How to delete old frequencies on bc340crs?
To reset the scanner to factory defaults, turn off the scanner. Then, while
holding down 2, 9, and HOLD, turn on the scanner. All scanner memory
contents are erased.
May 26, 2014 | Uniden BC340CRS Base Scanner
I want to clear all frequencys out of scanner
Turn off the scanner.
While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and "CLEAr" appears.
The above is from the "Resetting the Scanner" section on page 53 of the manual.
Mar 01, 2012 | Uniden BC-95 XLT Scanner
Cant get any frequencies to program
hi select a bank ,Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears. 2. Use the number keys and to enter the frequency (including the decimal point) you want to store. 3. Press E to store the frequency into the channel. Notes: • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency. • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475. • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning
Mar 18, 2011 | Uniden BC72XLT Handheld Scanner
How do I delete channels off of my pro-135 handheld scanner?
To RESET the scanner and delete ALL programmed frequencies:
- Power the scanner OFF
- Press and hold the 2, 9, and PSE keys and power the scanner ON.
To delete a single frequency, program 0.0 into the channel - or program a new frequency into the channel (this will automatically override the old frequency).
Bill B.
Dec 07, 2010 | Radio Shack Pro-95 Handheld Scanner
I have a radio shack hyperscan 200 channel pro-2039 programmable scanner. How do I erase ALL the stored frequencies so I can start over again?
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Oct 05, 2010 | Radio Shack Radio Communications
Cant get off lockout
If a channel does not have a frequency programmed into it, it will display 000.0000 and the L/O icon. Programming a frequency into the channel will automatically release the lockout.
To release lockout from a single channel, select that channel and then press the L/O key.
To unlock all programmed channels, select all frequency to ON, then press and hold the L/O key until the scanner responds with 2 beeps.
For a full reset of the scanner, press and hold the 2, 9, and HOLD keys while powering up the scanner. The reset will take about 3 seconds, and will be confirmed with a display of CLEAr. NOTE: this will reset the scanner to its original factory settings, and will delete everything that you've programmed into it.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
I hope this helps. Please contact us again if you have any other scanner problems.
BillB
Dec 24, 2009 | Uniden BC72XLT Handheld Scanner
How do I delete codes out of this scanner
Look in the owners manual, or online for the procedure. Or you can, as I remember, with the unit off, push number 2 and 9, then while holding down, turn unit on. Hold buttons until the display shows all zeros in the frequencie display. This will remove all frequencies so you can reprogram again.
Nov 04, 2009 | Radio Shack Pro-94 Scanner
Deleting frequcies
Clear out everything do the following
and CLEAr appears.
To take out individual Freq. Manually tune to that freq. Ch/Bank on the scanner. Enter 0.00 like a new freq for that ch. and it will be gone.
Jun 22, 2009 | Uniden BC72XLT Handheld Scanner
Cant get a answer on how to program my pro-97 scanner
here is a quote from the manual; hope it helps you.
1. Press MAN, enter the bank (0-9) and channel number (00-
99) where you want to store a frequency, then press MAN
again. M and the bank and channel number appear at the
upper left corner of the display (for example: M000).
Press FUNC. Then press e or d. The bank number moves in
the direction of the arrow pressed.
Press FUNC. Then hold down e or d. The bank number
moves continuously in the assigned direction.
Press e. The channel number moves upward one by one.
Or, press d. The channel number moves downward one
by one.
2. Press PGM. M changes to P.
3. Use the number keys and ./DELAY to enter the frequency
If you make a mistake, press CL to delete a single digit or press
and hold CL about 2 seconds to delete all digits.
4. Press ENT to store the frequency into the channel.
If you made a mistake in Step 3, Invalid Freq. briefl y
appears and the scanner beeps when you press ENT. Start
again from Step 3.
Your scanner automatically rounds the entered frequency
to the nearest valid frequency. For example, if you enter a
frequency of 151.553, your scanner accepts it as 151.550.
May 27, 2009 | Radio Shack Pro-97 Handheld Scanner
I am having trouble clearing out old frequences in my bc80xlt uniden bearcat 50 channel scanner. Any sugestions?
hi marie , follow these instructions carfully ,
1. Place the scanner on it's back on a hard surface with it turned "OFF".
2. Press down and hold down the following keys with your left hand. (MANUAL), (2) and (9)
3. While holding down these buttons, use your other hand to turn the scanner power "ON". Continue to hold all the buttons down until you hear a "click" and all the channels are cleared to 000.0000.
hope thats a fix ya .
Jan 03, 2009 | Uniden BC80XLT Handheld Scanner
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
