Question about Mitsubishi Televison & Video
I just replace the DLP chip on my MItsubishi 65" TV. Took photos and made sure connections are secure. Prior to the fix, the tv worked perfectly except for the white spots. Now the tv wont turn on.
The status light is solid red.; I have unplugged and also reset
tvguy171
  • 106 Answers
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Posted on Dec 19, 2008
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
CaptainHawk1
  • 345 Answers
SOURCE: My mitsubishi 65-inch dlp tv
It's either mirror hinge fatigue or dust on the inside.
Mirror hinge fatigue can be fixed by putting a solid color picture (white or gray works best from what I understand) on the display and letting it sit for 20 minutes.
If it's dust, someone is going to have to go in there and clean it out.
Also could be a defective micromirror device.
Try the first suggestion and if it doesn't work, you're going to need a technician to take a look at it.
Posted on Nov 23, 2010
  • 1156 Answers
SOURCE: getting white spots on my
Hi,all HDTV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board and also white spots.
A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens.
The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
Good luck.
Posted on Jul 18, 2011
chan_kurt_a
SOURCE: we just replaced the DLP chip in our mitsubishi 1080P tv because we had white spots all over the screen. Now after replacing the DLP chip we have no picture at all but we have sound. Help?
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
Posted on Dec 02, 2012
Black bar on dlp tv.how do I fix this?
Sounds like a connection problem between board and DLP chip. The BGA connection which connects the DLP chip to the board, or the flex connector may be bad, causing the row and column section to not activate the micro-mirrors on the DLP chip. Not an easy fix. Regards.
Nov 23, 2015 | Mitsubishi WD65737 65" DLP TV
Why does my DLP 60 inch Mitsubishi TV keep turning off and flashing a red light?
Your repair tech hinted correct. Although the bad connection will likely be in the power supply, it actualy can sit everywhere the power goes. Can be anordinary plug / connector with a little oxidatin, or a dab soldering point. Or perhaps a electrolitic cap, slowely dying.
Let the tech do his job. He has the tools, education and skills to keep your beloved TV alive.
Apr 01, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
I have a 65737 Model Mitsubishi DLP TV. I changed out the DMD formatter Board and DLP Chip Yesterday and now the Lamp will not come on. It worked fine until I changed the Board because it had Vertic
Hello, make sure all the covers are on correctly, then recheck all the wiring connections, unplug each one and inspect them for a bent pin. Let me know....tks
Jan 03, 2015 | Mitsubishi WD65737 65" DLP TV
How to replace a chip in a mitsubishi dlp television?
There should be a service accesspanel
just make sure you match up chip set numbers
Jun 02, 2014 | Mitsubishi WD65737 65" DLP TV
Mitsubishi tv 65 dlp chip
If you want to buy it, contact the authorized service center for Mitsubishi.
May 12, 2013 | Mitsubishi WD65737 65" DLP TV
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
Nov 21, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Mar 05, 2010 | Mitsubishi WD-73734 73" Television
Open Questions:
Televison & Video Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
