Question about The Toys
Purchased a 12v fisher-price escalade and it goes in low speed, reverse, and high speed reverse. Flipped the white plastic switch connections- no luck. Possible they wired the connections incorrectly?
iqbalq
  • 41 Answers
SOURCE: How do you change from low speed to high speed?
hi
there is a swich in the back of the car (L/low and H/high)
try it on high .
i hope this will work
Posted on Jan 06, 2009
  • 850 Answers
SOURCE: high speed-one wheel only,low speed-no,reverse
check for loose wires & or connections
Posted on Jul 27, 2009
  • 65 Answers
SOURCE: If you put it in forward low it goes in reverse
turn the switch around
Posted on Mar 31, 2010
  • 3 Answers
SOURCE: Thanks-car now only drives in high speed - not in
see "best solution" above. lift back end to see if the left wheel is not turning.If not that is your answer
Posted on Apr 11, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a Power Wheels
The switches are known to be bad on these Power Wheels. A lot of people just get a new three position switch from the hardware store and replace the switches. You can go to amazon.com and type in power wheels switch and find the one you need and order it. Either way, your problem is the switches. Both the forward and reverse and the high and low. Not the gas pedal plunger.
Posted on Oct 27, 2010
Does not operate in reverse
If the vehicle will not go in reverse, but works in both low and high forward speeds you most likely have a bad shifter switch.
The shifter switch is only available in a shifter assembly found here: http://www.mendingshed.com/j4390-9209.html
Replacing the shifter should get your Power Wheels running correctly.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 26, 2013 | Fisher Price Power Wheels Barbie Mustang...
How do i change the speed
There're is a screw in the shifter, take that screw out and there will be reverse and slow forward and shifter will now go up high to high forward
Sep 21, 2011 | Fisher Price Fisher Power wheels Cadillac...
How do I switch from low to high speed on a Jeep Hurricane. Shifter won't go into forward slot.
I have NO CLUE but it bet its a simple piece of Chinese plastic. Look down at the shifter, USE screw driver to remove shifter, remove Chinese plastic blocking the shifter from being pushed into HIGH by young child. Reattach shifter, push shifter forward to HIGH.
Nov 15, 2010 | Fisher Price Power Wheels Cadillac...
Jeep goes faster in reverse than foward
The shifter has two switches that it operates. Reversing the connecting plug on one of the switches will most likely solve your problem. It worked for me. The casing of the shifter should have a label "white" by one of the switches, leave that one alone, rather flip the plug going to the next one.
Jul 19, 2010 | Fisher Price Power Wheels Cadillac...
How do i put it in high gear?
go to battery compartment, youll see another plug up front by the front of the seat, plug it on and presto! use the pedal along with the throttle and youve got high gear..simple as that.
Apr 10, 2010 | Fisher Price Power Wheels Kawasaki KFX...
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Toys Logo
35 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
