Question about Northern Tool Welding Tools
I have a norther tool 5 speed drill press item 155734. First time I have used it and it will not power on.
I think it is the swithch because it moves very easy
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Delta Variable speed drill press will not spin belt freely
I would go to Dewaltservicenet.com and you can download a breakdown and also user manual for this tool with information about the set up and belt assembly, the breakdown would show you how everything is supposed to go in the pulley section. L et me know if you need further help
Posted on Oct 08, 2009
al_kupchella
  • 843 Answers
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
Posted on Jan 19, 2010
al_kupchella
  • 843 Answers
SOURCE: Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Posted on Jun 19, 2012
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    How do I remove both pulleys from top of unidentified drill press?
    15" Rockwell Drill Press pulley removal? - The Garage Journal Board
    www.garagejournal.com > ... > The Tools > General Tool Discussion
    May 3, 2012 - 7 posts - ‎2 authors I have 15" Rockwell Bench top drill press 15-017 I think circa 1971. ... You have toremove the machine screw and the pulley and bearing ... Drill Press Pulley Problem
    Aug 31, 2013
    Old COMPANION bench top drill press disassembly?
    Mar 5, 2013
    More results from www.garagejournal.com
    Oct 23, 2015 | Drills
    I need a manual for the 5 speed DP MINI 1/3 hp 1/2in chuck. I really need the assembly manual. Can u help me find this
    Northern Industrial Tools Benchtop Mini Drill Press - 5 ...
    www.amazon.com > ... > Stationary Drill Presses
    Amazon.com, Inc.Northern Industrial Tools Benchtop Mini Drill Press - 5 Speed, 1/3 HP - Power ... Yes the directions are bad as other reviews have said, but 3 bolts 3 screws and ...
    Oct 15, 2015 | Drills
    I am trying to drill through old encyclopedias, but the drill bits keep snapping in the pages. What type of drill bit can I put on an hand-held drill that will get through the books without breaking?
    rx-dk-diy054036_wood-drill-bits_s4x3_lg.jpgI've used 'regular' high speed drill bits for paper, and wood boring bits. I think the wood bits work better, but whatever bit is used the drill flutes have to be cleared out of material. This is done by drilling a little bit at a time and then lifting the drill out of the hole to clear the hole and the drill of shavings. This is essential to do to minimize heat buildup and binding of the drill bit. The drill bit should not break if you take it nice and easy, and drill in small increments .
    Dec 17, 2013 | Hinge European Drilling Tool 35mm Cup ...
    I need a chuck key for my Clarke 5/8" drill press, model BT1001. It's quite old but still works well. My only problem is I've misplaced the key, making it very difficult to change the bits. Thanks.
    you should be able to find a universal key that has four keys on it. ace hardware or local hardware should have it. if not call your local tool store to see what they have for similar chucks.
    Sep 01, 2010 | Clarke Power Products Clarke 16-Speed...
    I need a work plate for a drillpress #1000
    If you have the 5 speed model the table number is BT1000-0005 and you can go to Clarkeusa.com to order this part. That is where I found the breakdown for the tool. Let me know if you need more assistance.
    Mar 14, 2010 | Clarke Power Products Clarke 16-Speed...
    I need a chuck wrench/tool for a duracraft drill press
    Jan 17, 2010 | Drills
    Hi, I have a Clarke Drill Press Model No:- CDP 12HBN
    You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
    Nov 24, 2009 | Clarke Power Products Clarke 16-Speed...
    Beginner
    First of all, congratulations on your new place! I think this box is pretty useful for beginners: http://fadisel.com/Producte.aspx?referencia=1090
    Let me know if you need further help, and good luck!
    Burke.
    Dec 06, 2007 | Black & Decker Compact Power Screwdriver
    Welding Tools Logo
    361 people viewed this question
    Top Northern Tool Welding Tools Experts
    Bill Boyd
    Are you a Northern Tool Welding Tool Expert? Answer questions, earn points and help others
