I checked my network as the instructions said. I have a red x by each Netflix server 1-4 and an now-1-1000-4 and now-1-1005 on Internet connection?
DGolfer
  • 79 Answers
SOURCE: Internet
There is no utility that comes natively with XP to monitor traffic on an ICS connected LAN. I assume you are not directly connected to the ICS computer, and are running through a Switch or Hub? And you do not have access to this to see how many lines are connected?
If this is the case, you can download and install a packet sniffer and place it within the LAN in front of the ICS computer. It will 'see' all packets traveling across the wire, and report the MAC addresses and IP Addresses to which they are bound. Since every NIC has a unique MAC address (and IP Address), you can see how many computers (NICs) there are in the LAN, and connected to the wire.
http://en.wikipedia.org/wiki/Packet_sniffer
Ethereal:
http://www.ethereal.com/download.html
You can also use a utility like LanGuard Analyzer to search for all computers on the LAN:
http://www.gfi.com/lannetscan/
The last time I checked the trial version is fully operational for 30 days.. I use it in my Corporate LAN to monitor all 1000 computers in my domain.
One other thing to keep in mind, since ICS uses the Class C subnet (this cannot be changed), it has a limit of 254 clients that can be attached.. just an FYI..
Posted on Nov 22, 2007
SOURCE: Proxy Server Refused Connection
If you're using Firefox, click on "Tools" at the top of the page, click on "Options" which is at the bottom of the list that comes up, then click Advanced, choose Network from the four tabs below that. There should be a sentence "configure how Firefox connects to the Internet". Click on the button next to it that says "settings". and make sure that "Auto-detect proxy settings for this network" has a dot in the little circle. If not, click on it and click on OK.
You may have to shut down Firefox (your internet browser programme), then try getting in again. Should have sorted it.
Posted on Jan 05, 2009
frankzcomput
  • 268 Answers
SOURCE: Can't connect to westwood servers on red alert 2
Make sure to have you copy of windows as well as your copy of Red Alert 2 fully up-to-date
Thanks Live-Tech
http://www.mylive-tech.com
Posted on Jan 03, 2010
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
Posted on Nov 26, 2010
SOURCE: When I open Pandora internet radion under netcast
I'm having the same exact problem. Did you get your issue resolved?
Posted on Jan 16, 2011
Unable to connect netflix
I am assuming you are using a PC? if not use a PC on the same network, Click the start menu in "Run" type "cmd" in Windows 8/8.1 just type "run", once it is open type "ping 69.53.236.17" if you get a reply from that IP address, Your network can access Netflix servers and type "69.53.236.17" in the browser where "netflix.com" would go. if not, the modem or network firewall maybe blocking it. Hope this helps.
Apr 30, 2014 | Computers & Internet
Can't connect to TV
Most connection problems that prevent streaming occur on the device itself, or on the home network. In a nutshell, we will have you test the Internet connection on the device, log out and back into Netflix, restart your device, and restart your home network equipment.
Select your device from the list below for steps tailored to your device:
  1. Test the Internet connection on your device
    Many devices have an application to test the Internet Connection. If not, try opening the application store or another Internet-enabled application and check if your device is able to reach Internet services.
    • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Restart the device
    Restart your device by unplugging it from power for at least 10 seconds, then plug it back in and turn it on with the power button. Restarting the device is often enough to restore your ability to connect to our service.
    Note: All devices are different. Some may take up to 15 minutes to fully restart.
  3. Disconnect and Reconnect the Netflix application
    These instructions will work on most consumer electronic devices with the Netflix application.
    1. Launch the Netflix app.
    2. Using the arrows on your remote, enter the following sequence:
      • Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
    3. Select Deactivate and exit the screen.
    4. Restart the Netflix app and sign in to your account.
  4. Troubleshoot your Internet Connection
Oct 07, 2013 | Netflix
I can not get signed in on my xbox
Test the Internet Connection on Your Xbox 360
If you are having trouble connecting to the Internet or the Netflix service follow the instructions below:Test the Internet Connection on your Xbox 360
  1. From the Xbox 360 main menu, select Settings, then System, and Network Settings.
  2. Select Wired Network or Wireless Network depending on how you connect to the Internet.
  3. Select Test Xbox LIVE Connection and agree to Continue.
If the test reports that you can connect to Xbox Live, you have a healthy Internet connection. If the test reports that you cannot connect, seeMicrosoft's Xbox support site for more help.
Need more help?
Oct 06, 2013 | Netflix
I can't get the movies to play. I have tried turning the concole off then back on, software updates, internet connections, and tv connection. netflix said to contact you
In order to use Netflix on a game console the first thing you must ensure is that your device is compatible. The three main compatible consoles are the Xbox 360, Playstation 3, and Wii.
If you have one of these systems, follow the instructions for the system below:
PS3:
1) Make sure your console is connected to the internet.
2) Log on to Playstation Network and download the Netflix app.
3) Install the app, then run it.
(NOTE: Playstation Network is currently down for maintenance. More than likely Netflix will not work until it is back up)
Wii:
1) Make sure you have a wireless network set up in your home.
2) Follow the Wii's onscreen instructions to connect to your network.
3) Go to to the "Wii Shop" channel on your Wii and download and install the Netflix app.
4) Run the app and follow the instructions.
Xbox:
1)Make sure your Xbox is connected to the internet
2) Log into Xbox Live with a Gold account.
3) Download and install the Netflix App from the "downloads" section.
4) Run the Netflix app and follow the instructions.
Mar 09, 2011 | Video Game Consoles & Games
Trying to launch netflix streaming and i got the message "there was a problem communicating with the Playstation network. Please try again later." How do i fix this?
Apascual67 -
There are quite a few problems that could lead to you getting that message. In order of easiest to hardest to fix, here's a few of them:
1: It could be that your PS3 is not connected to the internet.
  • Try going to the browser on the Playstation, and try loading a basic webpage, like www.google.com. If that works, then try Netflix again.
  • If you're not connected to the internet, then go back to the main menu, and go to the internet (or maybe it's called network, not sure) settings. Sign in to your home or dorm's wireless network, if there is one. I can't help you with that, as each network is different.
  • If you cannot connect to a wireless network, or if one is not present, then try connecting your PS3 to the internet using an ethernet cord, if you have one. (It looks like a phone cord, but the ends are bigger.)
2: If you are connected to the internet, and you still can't access Netflix, then there's a few more things to try.
  • Most easily, turn your Ps3 off then on again. I'm not super sure if that will fix it, but it can't hurt to try.
  • Make sure that you're using the correct username/password to sign in to the Playstation Network, and that you're using the right combo for Netflix.
3: If none of those work, then there could be a deeper network problem. Perhaps your home internet is set up incorrectly, or maybe Sony or Netflix are having server problems. Whatever the reason, I can't help beyond this.
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
The Netflix app on my vizio svt422xvt (one of the Vizios with VIA internet & wifi built-in) won't connect to Netflix. It directs me to the Netflix website for help, but Netflix help tells me to...
Aug 11, 2010 | Televison & Video
I cannot set up Netflix. Player says it was successfully connected to my wi-fi, but I don't know what to do next.
There are several possibilities why the NS-BRDVD unit isn't connecting to the Netflix server.
Your internet connection speed is a possibility. 1.5Mb is too slow. 4.5Mb is preferred and even faster is better.
Do you have a firewall that is up? If so you may need to instruct your firewall this device is allowed to connect.
Your distance from the WiFi router is too far for a stable connection.
Have you tried using the wired connection to make sure your player is working correctly? That your network is allowing you access?
I would start with a wired connection direct to the internet. If that works, start introducing new components until the connection fails. When you find the failure point you will know what item needs to be changed. How to change that depends on how you setup your network.
Hope this helps!
Feb 27, 2010 | Insignia NS-BRDVD Blu-Ray Player
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
