Question about Radio Communications
How to set radio frequency e.g. 105.1 - Radio Communications
  • 9 Answers
Ms. Mary,
First of all, Happy New Year -- hope it will bring you great things.
As to your question: it's a bit on the vague side. What make and model is the radio? Instructions pertaining to your answer will depend pretty heavily on the fundamental information.
Looking forward to being able to help you out. I've been a ham over 55 years, and a commercial two-way tech over 40.
Posted on Jan 01, 2017
How do I extend the radio frequency from 80 MHz to 105 MHZ?
No possible due to the frequency band of the radio. Governed by component values.
Apr 30, 2015 | Radio Communications
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Jun 02, 2011 | Car Audio & Video
Can't find the clear tuner fm frequency
I have a JVC deck myself and had the same problem but if you read the manual it recommends that owner should use mono mode when using FM. Since changing to mono I am able to locate radio stations (frequencies).
Here is the link to the manual
Sep 19, 2010 | JVC KD-LX50 CD Player
Problem with the radio
THe frequency stepping cannot be changed on this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Alpine CDA-105Ri CD Players
What frequency should car radio be on to access xm
Go to your radio's MENU and set a frequency, then set your car to the same frequency.
Apr 24, 2010 | Delphi Roady XT XM Radio Receiver
The rds on my cmt ws2d shows the radio statio name
Radio Data System does need a good signal. You may need a better antenna. You don't actual say what you have for an antenna! So I can't say it's that. However not all Radio Stations broadcast the track name. And some don't broadcast any names of tracks. Some just tell you the name of the station and something like "all the best music on FM 105".
Feb 13, 2010 | Sony CMT-WS2D Shelf System
It transmits off frequency is there a adjustment and also the frequency counter goes crazy at times
To add 10Khz to your transmit frequency:
The left position puts the radio on
one of the three fixed channels that is selected by the channel switch
(6,19, or 21). This over-rides the channel selected by the 40 channel
knob. The right position adds 10KHz to whatever frequency you are ON.
In the middle, both features are OFF.
Otherwise, a radio tech would be able to retune the frequency inside the radio.
After adding 10KHz to your frequency, use the SWR control to check the SWR of your antenna.
Here's how:
SWR CAL CONTROL: Normally this switch is set to “PO”. Then,
during transmission, the meter indicates output power. To read SWR,
rotate this knob during transmission until the needle moves to the “SET”
point on the SWR scale. Then, while still transmitting, set the R.B./SWR
switch to SWR.
Ideal SWR is 1 but you'll want to be as near one as possible. An SWR of 1.6 or greater will make ineffective use of your antenna.
If in doubt, a radio tech has the required meters and tools to adjust the SWR/Tuning of your antenna.
May 10, 2009 | Galaxy Radios DX-73V 40-Channels Base CB...
Cannot set fm frequency on radio
Go through the Settings Menu on the Reciever until you see Frequency Select It and then turn the dial until it matches the same frequency that you are using on the Radio.
Jan 01, 2009 | Sirius Satellite Radio Receiver
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Radio Communications Logo
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
